Old 12-02-05, 07:24 PM
header tank pipe size
Hi, could someone do me a favour and measure the size of their pipes exiting from their coolant header tank, I am building a Dax with a Big block Ford V8, just mocking up the tank in 4" ally and need the optimum sizes for the pipes, thanks in advance. dave
Old 12-02-05, 08:41 PM
madjohnny's Avatar
Re: header tank pipe size
Dave, have just measured mine on the Dax supplied header tank, 5/8", 5/16" on the main tank body and 1/4" on the filler cap neck.
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 13-02-05, 11:42 AM
Thanks John, what circumference is the off the shelf Dax item? and what distance from the top of the tank is the 5/16" feed to the therm? thanks for your help. Dave. ps I was going to use 4" tube, 9" long, think that will suffice?
Old 13-02-05, 04:33 PM
regarding the header tank , i have made one which is 14 inchs long by 4inch diameter. i have placed a rad cap and overflow on top, and a 1/4 inch connection towards the bottom of the tank , this is connected into the overflow on the existing radiator. i have fiited a cap with no spring on it, this works fine, i only need it to take up the expansion in the water system and also take out any air.
adrian
www.americanv8engines.co.uk
Adrian
Old 13-02-05, 05:16 PM
madjohnny's Avatar
The Dax supplied item is 208mm long and 130mm Diameter.
See attached pics for an idea of outlet placement.
Cheers, John.
MJ's Gallery
Old 13-02-05, 05:41 PM
Thanks John/Adrian, just what I needed to know. Dave
DAX header tank chesterak General Cobra Discussion 17 11-09-06 12:38 PM
Header Tank bc_suv Pilgrim Sumo Technical Questions 5 26-03-06 09:06 AM
Header Tank mikey General Tech Tips & Questions 0 31-12-04 08:26 AM
header tank pipe? MARTIN123 General Tech Tips & Questions 21 18-12-03 10:02 PM
header tank David J General Tech Tips & Questions 8 25-07-03 06:52 PM
