Old 20-02-05, 03:10 PM
which cooling fan?
Hi, just need some feedback re cooling fans, I need to cool a big block ford and am looking at what fan to use, would appreciate some ideas/advice on specific makes/types, I am thinking of using a 16" Pacet or similar? any info as always gratefully received, Thanks Dave
Old 20-02-05, 03:33 PM
Re: which cooling fan?
Hi, had a bad experience with a 16" Pacet bought through Dax, but apparently they had a bad batch with a problem. I replaced this with two 13" Heavy Duty fans from Kenlowe. Great customer service, quick delivery (next day I think, if its in stock), comes with a set of metal brackets that easily adapt to connect with the existing radiator brackets. Not cheap, but then they more than do the job - one on its own is sufficient to cool in normal traffic queues. I have one thermostatically controlled, the other on a switch.
Personally I don't like the idea of being stranded because I only have one fan and it gives up (hence my bad experience with the Pacet), and on hot days two might become necessary anyway - particularly if you have a BB. Kenlowe also do single 16"s which are apparently sufficient for a small block. Give them a call, they'll talk you through choosing.
Andy :thumb:
Dax, Chevy 350 & Performer RPM Kit, Tremec
Ferrari Rosso Barchetta Red
Old 20-02-05, 03:39 PM
I went for a single 16" kenlow fan, with a dash light to show when its working and a manual over-ride switch to bypass the thermostatic switch should it be necessary.
Mounted in front of the rad, it also helps protect the rad from debris.
This is for an RV8 powered Sumo
David
Old 20-02-05, 05:02 PM
Thanks for the replies, I like the idea of two fans, with one as a backup or to use when the temp dictates, with a swith to activate independently, as always appreciate your time. Dave
Old 20-02-05, 07:01 PM
I too can recommend kenlowes. I bought a car 25 years ago that had had an engine fire. The twin kenlowe fans were completely melted but I managed to get them off and the motors were fine! I bought new blades from the guys at Burchetts Green and the same units are still going fine and installed on my Cobra. Good kit, and yes, very helpful and professional outfit.
Myles D-W
Old 20-02-05, 07:36 PM
Hi,
I run two 13" Kenlowes and never had a problem.
Cheers !!
David
Old 20-02-05, 08:49 PM
David,re your setup running two 13" kenlowes, can you elaborate on the fit/wiring/setup? any info/pics/advice would be great, and yes, looking forward to sucking huge gobs of gas and kicking plenty of ass!!! thanks Dave
Old 20-02-05, 11:28 PM
I will post some pics tomorrow, wiring is dead easy (even I could do it) !!
All details come with the fans! :thumb:
Cheers !!
David
Old 21-02-05, 08:09 AM
Thanks david. Dave
RV8 Cooling again! janandchris Pilgrim Sumo Technical Questions 56 11-07-07 07:57 PM
Ram 350 with oil cooling bitsilly General Cobra Discussion 9 17-03-06 07:33 PM
Help with cooling Steve Senior General Tech Tips & Questions 11 13-09-02 08:54 PM
RV8 cooling chesterak General Tech Tips & Questions 5 10-08-02 04:02 PM
Cooling RTM General Cobra Discussion 15 08-01-02 11:03 PM
