Old 22-02-05, 11:07 AM
dave.n's Avatar
Fuel pumps
I have a Holley Blue electric fuel pump.
Ever since I have had the car there has been a wiff of petrol in the boot. Checked for leaks and tank breather, all seemed ok.
There is evidence of a fuel mark on the wheel arch under the pump, but I have never found a leak. Until now.
I have sat in the garage with engine running, boot open for longer than one should. So I could be halusinating and it obviously affects spelling.
There is a small @1mm diameter hole on the side of the body. This seems to be weeping. After quite sometime a small drip eventualy falls of off the back of the pump to create the mark and the smell.
I have been advised this is due to a sceal in the pump and should be replaced.
Real Steel say that you can no longer replace bits therefore a new pump.
Holley Red= @£90.00
Carter 4.5-6.5psi=@£60.00
Customville recomend I use another Holley Blue at @£114.00 and throw away the regulator as it comes with a seporate regulator and you can't split the box. They also say a Carter fuel pump won't be enough on full tilt and a Holley Red won't be a good match for the existing Holley Blue regulator.
Rather than put a mechanical pump on I thought it would be easier to just un-bolt one and replace with another.
What do you recon guy's
I have a ford 302,fast road cams, edelbrock 600cfm. Running with a constant 6psi fuel pressure.
billy no mates . South East Regional Rep
SRV8
Old 22-02-05, 04:14 PM
dave.n's Avatar
Re: Fuel pumps
So 34 views and nobody has any ideas.
Or they simply don't give a toss 'cos theirs are ok. And they think I'm a :whatever:
Love you all.
SRV8
Old 22-02-05, 05:00 PM
Andy S's Avatar
Re: Fuel pumps
Dave it must be difficult when reality strikes !!!!!!!!!!!!!!
Andy S (Maggot)
SRV8 + CHEVY
Isnt it a beautiful day - now watch some bastard louse it up !
Old 22-02-05, 05:18 PM
dave.n's Avatar
Re: Fuel pumps
Andy
Safe journey
SRV8
Old 22-02-05, 06:05 PM
dave's Avatar
To you, to me.
Re: Fuel pumps
Why don't you fit a mechanical pump? No smells, no pressure worries and 10 a penny prices. The only reason for not fitting a mechanical pump should be space problems or fuel injection.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 22-02-05, 06:13 PM
Re: Fuel pumps
Dave,
I have a Carter and it feeds plenty!!
I'd go for the Carter.
GUMBALL
Too many idiots, not enough villages!
Old 22-02-05, 06:15 PM
kdavies3's Avatar
Re: Fuel pumps
I totally agree, I run a 6 PSI mechanical on mine with no problems even on the track. :thumb:
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 22-02-05, 06:26 PM
gwak76's Avatar
Re: Fuel pumps
I have a Carter fitted at the moment and it keeps the carb fed at 5-6 psi at WOT, works for me :thumb:
Gary
Custom Exhausts & Headers
ww.sidepipes.co.uk
Old 22-02-05, 06:37 PM
Club Sec/Rep Liason
Re: Fuel pumps
The standard Carter electric moves 72 gph. 120mph for 1hour @ 5mpg = 24 gallons.
AK 427 351C T5wc
Old 22-02-05, 06:46 PM
dave.n's Avatar
Re: Fuel pumps
Not only am I known for being Billy, but I'm also known for being the first one needing fuel on a run.
Hopefully the new carb has helped a bit on that front.
If a Carter will do the job I'll get one tomorow.
Anyone got a picture I have no idea what shape or size they are. (alterations and stuff)
I have just been informed the Carter is much quieter than a Holley.
SRV8
Facet Fuel Pumps qkingston General Tech Tips & Questions 2 16-09-07 11:48 AM
Facet fuel pumps, do they overheat? maxGD059 General Tech Tips & Questions 22 24-10-05 08:17 PM
Fuel Pumps - Im baffled!! Martyn-ak427 General Tech Tips & Questions 13 24-08-05 10:26 PM
Noisy Fuel Pumps nick206 General Cobra Discussion 13 05-09-03 05:08 PM
Jag fuel pumps andybearne General Cobra Discussion 3 02-05-03 02:10 PM
