| Re: Help wanted did changing the heads have any effect? what colour is the smoke? What engine
| Re: Help wanted Howard What type of fuel injection have you got. There are some websites with diagnostic checks to follow. I've just found the link below in my favorites, there are more depending on your injection system Steve http://www.landroverclub.net//Club/HTML/ECU_check.htm |
| Re: Help wanted Quote:
Changing the heads had no effect and the smoke is black. The engine is a fuel injected Rover Vitesse 3.5. Cheers
__________________ Howard Viper under construction - full steam ahead and hopefully on the road this year. |
I've got the Lucas flapper injection system, I'll do some checks over the weekend. Cheers
| Re: Help wanted Howard, When you changed the heads did you have the injectors cleaned? I have found before that if even one injector is slightly blocked it will give you poor atomisation within the cylinder, thus creating poor combustion and smoke. Russ
No I didn't get the injectors checked but I'm beginning to wish I had now. I'm going to do a compression test at the weekend to try and eliminate, or point the finger at, the piston rings. Do you know what PSI I should get ? The heads are recon with new valve seals so they should be OK, which should only leave the fuel system. Do you agree with this approach or can you advise differently ? Cheers
A compression test would be a good idea, this would establish your peak pressures. You should find what your compression rate should be in haynes manual for your engine. One word of caution though, you say your heads are recon. 9 out of 10 times when heads are recon'ed they are skimmed to ensure they have a true and square face, thus slightly increasing you compression ratio. All i would say is that if you have any cylinders with a lower compression that the rest, that cylinder needs further investigation. The norm reasons for low compression is 1, piston rings gone - if this is the case the engine will be breathing heavy. 2, valves arn't sealing correctly in their seats- but this should not be the case if youv'e just had them recon'd. If compressions are O.K i would get your injectors cleaned and tested to see if your getting a good spray pattern and atomisation. I hope this is of help. Russ
| Re: Help wanted I would certainly clean the injectors. You could try swappng em over to the opposing banks and see if the problem moves.
| Re: Help wanted Hi guys As always your help and advice is appreciated. I'll let you know what the compession test results are. Thanks again
| Just wanted to say Hi to everyone | Ian 46 | Newbies | 16 | 15-07-07 10:51 AM |
| MGB wanted | kurrmet | General Cobra Discussion | 26 | 28-06-07 06:47 PM |
| I wanted to be the first............ | Neil O | South West | 6 | 26-10-06 06:33 PM |
| Wanted | Clarkson | General Cobra Discussion | 0 | 02-08-05 10:31 PM |
| Wanted | simon | The Cockpit | 2 | 08-06-05 11:32 AM |
