  #11 (permalink)
Old 13-03-05, 07:17 PM
Re: octane rating
I did the PPL(H) thing too, a few years ago, great fun but certainly the most challenging thing I have ever attempted.
Myles D-W
  #12 (permalink)
Old 13-03-05, 07:20 PM
Re: octane rating
Thanks guys, its good to know we cobra drivers share other interests to. It certainly is chalenging myles, almost as challenging as building a pilgrim sumo, the only thing the cobra has in its advantage is there are no exams.
So many happy miles and landings
Anthony
ANTHONY
Pro cobra builder
Current build No. 16
  #13 (permalink)
Old 13-03-05, 08:01 PM
Re: octane rating
When I first moved to NZ I worked for a day or two as a 'driver/loader' which is the guy who refills the crop spraying helicopter each time it lands. The most amazing experience and got some flying in too. Crop spraying up in the mountains is REALLY flying on the edge, the helicopter was fitted with sharp blades above and below the cockpit the idea being that if (when?) you hit cables they will be chopped off rather than bring you down!!
Myles D-W
  #14 (permalink)
Old 13-03-05, 08:31 PM
Re: octane rating
Hi Keane,
I would suggest that you dont go more than about 10.2:1 CR using standard pump fuel in the UK otherwise ir will cost a small fortune in additives.
I would aim for around 9.8 - 10.0 CR if you can!
Cheers !!
David
  #15 (permalink)
Old 13-03-05, 08:51 PM
Re: octane rating
Originally Posted by CrendonMan
Hi Keane,
Surely the amount of static CR you can run depends very much on the valve timing (cam choice). If the cam has more overlap you can run a higher static CR without problems.
Myles D-W
  #16 (permalink)
Old 13-03-05, 09:48 PM
Clarkson's Avatar
Speed junkie
Re: octane rating
My engine is 10.5:1 on 98 fuel, I have ali heads.
David:thumb:
David
2nd baby due 23rd Jan.
  #17 (permalink)
Old 13-03-05, 10:57 PM
Re: octane rating
As Myles has suggested simply stating static CR is not enough(SCR). You need to calculate the dynamic CR (DCR) which is based on valve timing.
Running 11:1 on a fairly mild engine will be fatal.
An engine with Cam specs around 300 Degrees Advertised or 255 @ 0.05 would give a DCR (in the region of 7.75:1) that would support a SCR of 11:1 though you may run into premium petrol territory.
Another point of consideration is the quench or squish clearance. This has to be very carefully set to prevent detonation in high CR engines. Head to piston gaps down to 0.8mm need to be considered.
This gentleman has written a good article on the subject and includes on his web site a link to a calculator for DCR.
http://cochise.uia.net/pkelley2/DynamicCR.html
As a rough guide a 350 built as a balanced well engineered project with quality ally heads should produce around 460-470BHP at around 6500, if this is the type of engine you are aiming for step boldly onwards!
I hope this is of some use to you.
All the best
Paul.
  #18 (permalink)
Old 14-03-05, 07:52 AM
Banned
Re: octane rating
Originally Posted by keane
Hi, before I go and use too much CR, what octane are the UK fuels? I am going to be close to 11-1 so will need some decent fuel to prevent detonation. thanks Dave
I use Optimax which when tested by the Germans recently turned out to be 99 octane not 101 as claimed, CR 11:5.1, single advance curve (1,000rpm to 3,100rpm) and no problems Osgood
  #19 (permalink)
Old 14-03-05, 08:03 AM
dave's Avatar
To you, to me.
Re: octane rating
Hi Eric.
I was under the impression that Optimax here in the UK was 98 RON.
Have a look at this.
RON, MON or PON?
Or how do you grade petrol/gas
I have seen many European/US conversations claiming that one petrol/gas is better than another or higher rated. This may not be the case as different rating systems are used in different countries and so not all numbers mean the same thing. You must be careful to also quote the measurement system used
To see why there are different numbers let us take a trip back in time to World War I. Aviators had a problem, many engines would suddenly self destruct through detonation, which is bad news when you're up in the air. An engine might run fine on one batch of fuel but blow holes in the pistons on the next batch. The fuels seemed the same, weighed the same and may have even come from the same factory.
The fuel companies tried to analysis and standardise the petrol, but were unable to weed out the bad batches. Therefore a standard test engine with a variable compression facility was built and the fuel to be tested run through it. This heavy duty, single cylinder engine would be warmed to a standard temperature and at a set rpm the compression increased until engine knock occurred. this would give its Highest Usable Compression Ratio (HUCR).
But with time it was discovered that different labs gave different results. So in an attempt to produce an unvarying standard, two reference fuels were chosen. The high reference was 2-2-4 trimethylpentane (iso-octane), while the low reference was normal heptane (n-heptane). Once the HUCR was determined a mix of these to fuels was made up that exactly produced the same results as the HUCR test. The result is quoted as the percentage of iso-octane. Hence a petrol that detonated the same as a mix of 90% iso-octane and 10% n-heptane is called a 90 octane fuel.
Since that time a number of tests have come into being to simulate a variety of engine conditions. Motor Spirit is usually rated using the Research or Motor test methods. Both use the same old engine but under different conditions
Motor Octane Test (MON) Research Octane Test (RON)
Inlet air temperature 148.9 C 65.6 C
Engine jacket temp 100 C 100 C
Engine RPM 900 600
As you can see the Motor Octane Test employs a higher temperature and RPM and hence is probably a better indicator for today's engines. Of course the Research octane test gives a higher number and that's why the European manufacturers quote it (RON)
The spread between the two numbers is know as the fuels sensitivity, and it is very important. Because of the variety of engines it is possible for a petrol manufacturer to come up with a fuel that has a high RON, but a lower than expected MON. Hence although it looks normal on the pump it may perform badly. However on another day the same company may make its fuel out of a different blend to get the same RON but a different MON. This is done for profit reasons and is why you occasionally get bad fuel even though it is legally rated the same. In the past with high leaded fuels nobody noticed but nowadays high performance cars do notice (The Molemobile has just had a particularly bad batch from Total, and has been pinking all week)
In America the service stations use the Pump Octane Number or PON rather than RON. this is the average of RON and MON and gives a much better grade, and is also why the American gas always seems not as good as our when in fact it is is the same (and has better quality control). But even this system can be abused by adding octane boosters to poor fuel.
Below is an approximate comparison chart, these numbers can vary by as much as 2 grades
RON MON PON
90 83 86.6
92 85 88.5
95 87 91
96 88 92
98 90 94
100 91.5 95.8
105 95 100
110 99 104.5
So now you know far more you wanted to about RON, MON and PON. Knowing this you might begin to wonder why certain garages are always cheaper than others, and experiment with different fuels. I'm lucky, my new job has just given me a fuel card for private use, so I'm moving up to super unleaded, that way I can be assured I'm getting at least 95 RON
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
  #20 (permalink)
Old 14-03-05, 06:01 PM
Banned
Re: octane rating
Dave are you having a go or what Mealy quoting words from Dave Butcher a 289 man who lives in Germany on a write up by the German government re tests they did. Yes perfectly aware that Optimax is 98 RON stamped on the pump and I can read unlike some!!
According to the writings in some one else's hand posted by yourself 98 RON is some-where between MON&Pong then which equates to 92 octane who knows Dave I am not a physicist and neither are you All I can say is I have no problem with either Shell Optimax or Esso Super unleaded or what ever they call it now at 11:5.1 which was what the guy asked in the first instance Eric.
De rating Diffs? Grease Monkey General Tech Tips & Questions 9 28-09-07 07:25 AM
Radiator cap - Pressure Rating? Clive General Tech Tips & Questions 3 15-07-07 08:25 PM
Octane Louise General Cobra Discussion 0 26-10-03 07:47 PM
fuel rating and oil cooler craigh General Tech Tips & Questions 1 05-08-03 10:01 AM
User Rating robert Admin Announcements 0 18-09-01 12:12 PM
