Old 03-04-05, 08:39 PM
ignition light
Can any one tell me why ignition light flickers on at approx 2000 revs upwards and voltmeter stays at a constant 13v. Fan belt is tight enough. Any ideas would be appreciated
roger
Old 03-04-05, 08:56 PM
Re: ignition light
At a guess the volt meter is showing the voltage of the whole system, ie including the battery, so even if the engine stops it will still show the battery voltage.
The charge light however is wired in to take 12v from the battery and an input from the alternator. When the engine is off, you get 12v (from the batt) and 0v (from the alternator), so the light comes on. When its running you should get 12v and 12v so no voltage potential so the light stays off.
If your light is coming on, you must have a lower voltage coming from the alternator.
Old 03-04-05, 08:59 PM
gareth08's Avatar
Re: ignition light
Could be a diode/rectifer pack on it's way out.With engine ticking over turn on everything electrical and volt meter should stay at around 13 to 14 volts and you should notice a slight drop in engine note as alternator takes up the load.
Gareth
Gareth
Old 03-04-05, 09:01 PM
Re: ignition light
Hi Adrian
Volt meter shows a constant charge when engine is running and drops down when turned off
roger
Old 03-04-05, 10:24 PM
Re: ignition light
The volt meter could be wired to ignition live, so no ignition no power to the dial.
As stated, your regulator's probably stuffed.
Old 03-04-05, 11:21 PM
madjohnny's Avatar
Re: ignition light
13v at 200rpm sounds a bit low anyway, should be more like 14v.
Check all the connections both from and too the battery, alternator and ignition light.
The ignition light is normally fed from the multi pole connector coming from the alternator.
Check this is also secure.
Otherwise, as stated, sounds like the alternator.
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 04-04-05, 09:43 AM
Re: ignition light
Take the alternator to a decent auto electrian and the should be able to test it on a jig for you
Keith S
Built a Sumo 3 RV8 Sold it to buy a 2000 Chimaera 4.5
Old 05-04-05, 02:42 PM
Re: ignition light
der ! I tightened up fan belt - now ignition light doesn't flicker at higher revs - sorry guys for wasting your time.
roger
Red warning light BOJAY DAX Technical Questions 11 15-06-07 12:03 AM
Seen the light John k DAX Technical Questions 11 20-07-06 10:41 PM
Ignition Light stays on Karl Engine Tech Tips & Questions 5 10-07-03 07:19 PM
Timing light graham General Tech Tips & Questions 8 02-08-02 09:24 PM
So how do I use a timing light? nbracken General Tech Tips & Questions 12 19-05-02 09:35 PM
