| Jag Front Suspension Guys, a quick question re Jag front suspension On the top wishbone mount, where it attaches to the chassis via the bushes, there are two nyloc nuts holding the wishbones on and compressing the bushes (upper fulcrum I think) On mine, when the correct(?) torque of 55ft/lb is set on these nuts, there is not enough thread passing through the nuts to pass the SVA. (The nuts are the right size - they are not very deep.) Anyone had a similar problem? There is a very thick washer under the nuts to provide pressure on the bushes (as well as the chrome thrust washer) can I replace with a thinner one? Thanks Pete
__________________ Pete GD Jag, 350 Chevy, Tremec TKO |
| Re: Jag Front Suspension Dave, Thanks for the reply. I spoke to AB today, and he suggested replacing the thick washer with a thinner one. As for SVA regs, he says that 1 and a 1/2 threads showing on a nyloc are sufficient. He also said that if some form of locking device is required - nyloc, spring washer or threadlock will do, so rather than replacing bolts, you could use a different method, but from what you say, it seems that you have enough anyway. On closer inspection, I also have a problem with the N/S upper ball joint and the N/S track rod end......just when you thought it was safe to say it was ready....:angry: >>Just getting my Rad lower hose anglre shifted because I took the GD advice and fitted the rear rad fans on a Jag build and haean issue with the clearence between the steering rack gaiter and the fan shroud.... no problems all the minor tasks tend to be the biggest time waster.<< I put the fans on the front for some protection, but they look neater on the back. I agree, its all the silly little jobs that take the time, but hey, what would we do while waiting for an SVA date? (I sent the form off last week:thumb: ) Pete
| Re: Jag Front Suspension Quote:
| Front suspension -How Stiff? | Simon R | General Tech Tips & Questions | 2 | 28-03-07 12:39 AM |
| sumo front suspension | stevem | General Cobra Discussion | 21 | 27-04-06 09:10 AM |
| Dax De Dion Front Suspension Set-up | MickyB | DAX Technical Questions | 5 | 07-04-06 10:52 AM |
| Jag front suspension? | garyholden | General Cobra Discussion | 7 | 19-08-04 01:18 PM |
| Front suspension | Miket | General Tech Tips & Questions | 6 | 26-01-02 10:11 PM |
