| Attaching Interior Panels/ dash Hi guys, nice quick one for you here.... Im about to start making up my interior, but am unsure of the type of clips to use to attach the side panels to the doors. Ive seen the little black plasticy type push in screw things but how do you attach those to the panel underneath the trim (leather)? Also the dashboard fastenings, if im going to use bolts then how do you stop them from turning when fastening and also how do I make them not visible under the trim? cheers Ben |
| Re: Attaching Interior Panels/ dash For what its worth this is what I did.... Dashboard Grind down M8 screws until head is only a mm or 2 high. Dril hole in dash (before covering) and lokcnut in position. Cover front and back of fixing with epoxy. Sponge will cover the front part, and at the back use nutwith a lockwasher or springwasher - doesnt need to be done up that tight as its not carrying much load. Alternatively, use coach bolts. Other panels (could have done the above till I found....) black plastic push-in panel mountings from Halfords. Just drill hole in panel and push through. Then cover panel. Mark corresponding positions on body, drill holes, push mount panel. Job done. Kevin |
| Re: Attaching Interior Panels/ dash ah right so the for the push in jobbies, the clip into the panel themslves do they.... you wouldnt happen to have a piccy of those would you? Ok that makes sense about the dash, If I dont use nylocs on the back then it isnt gunna be under much stress to turn it so should be ok figure tight I suppose....but with a spring washer it aint comming off.... cheers Kevin Ben |
| Re: Attaching Interior Panels/ dash Used a little more archaic method, but it works a treat. Blue skies If I've said it once, I've said it a thousand times - "Inexpensive means Inefficient". ----------------------------------------------------------------------------- * * It's: "SPLAT - THE DOG!" -//-//-_ +> --__ Slower than a speeding DISCO. Much slower. +>/ _------__ Mortally slower, one might say. Rest in Peices. -\-\-- * * ----------------------------------------------------------------------------- "Rest in Peices" just like my old Rangey. Er, think that was Rust, not Rest. . . |
| Re: Attaching Interior Panels/ dash Woolies sell green trim clips for your interior panels. These clips fix round the end of th ply that you are going to put your trim on and then just pop into holes you drill in the inner door skin. Completly invisible. |
| Attaching headlamp rims | bitsilly | General Cobra Discussion | 2 | 21-09-07 10:49 AM |
| Interior door panels | hfbradley01 | Viper Tech Forum | 5 | 28-06-07 08:26 PM |
| Attaching the side vents? | CraigSimpson | Newbies | 11 | 31-05-06 11:43 PM |
| Attaching the cable to the Carb | chedz | Pilgrim Sumo Technical Questions | 8 | 04-03-06 11:51 PM |
| Attaching & covering the dash... | duncanh | Pilgrim Sumo Technical Questions | 2 | 06-05-04 01:46 PM |
