Old 01-05-05, 06:40 PM
kevchard's Avatar
Securing copper fuel pipe to rubber hose
Has anyone any pearls of wisdom attaching rubber (not so flexible) fuel pipe on engine to copper 8mm fuel pipe. I have seen the term swageing, but not sure what this means. Can i use my brake pipe flaring tool to prepare the copper pipe?
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 01-05-05, 06:58 PM
madjohnny's Avatar
Re: Securing copper fuel pipe to rubber hose
Hi Kev, usually the ends of copper pipe are flared to prevent rubber fuel line from coming off once they have been clamped up with a jubilee type clip.
I used a basic type of flaring tool on my 10mm copper pipe to ensure the rubber fuel line will not come adrift.
If you are going to use this type tool on it be careful as with mine if I flared the pipe fully it was almost impossible to get the rubber fuel line over the end, as you have already stated it is not overly flexible.
Another option which I think is acceptable at the SVA test centres is to double jubilee clip the pipes.
Personally I'd rather flare the ends, much safer!
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 01-05-05, 07:04 PM
steamyrotter's Avatar
Serial Complicator
I read somewhere you need to use a double flare.
Flare and a (couple of ) clips should see you OK.
You have to be more onerous with injection to withstand the higher pressures.
regds
D.
Dean.
Old 01-05-05, 09:28 PM
kevchard's Avatar
Can you double flare with the horseshoe 'former type' flaring tools? I may buy some new rubber as i presume it goes hard with time.
V quiet on here, you can tell stoneleigh is on.
Cheers for now.
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 01-05-05, 10:37 PM
Serial Complicator
Not sure!!
However a flare plus 2 clips will give a very secure fixing, and should be OK for SVA?
(I Hope!!)
Dean.
Old 01-05-05, 10:56 PM
hi kev
what about soldering some copper wire to the pipe and then using a jubilee...won't be as good as an 'olive' but have you tried a plumbers merchant to see whats available ?
NEIL
Old 02-05-05, 12:41 AM
I'd advise not to solder in-situ using a torch...
Reverend Robin
GD427 Euro
World Rivnut Champion 2007
Old 02-05-05, 09:22 AM
Robin
You have no sense of adventure!!
Denis
GD427E039
Old 02-05-05, 09:25 AM
kevchard's Avatar
'Robin
You have no sense of adventure!!'
Or eyebrows probably lol
Cheers, i will try a single flare and jubilees and new rubber fuel pipe (more flexible).
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 02-05-05, 09:48 AM
Any DIY store will sell olives for 8 or 10mm pipe just get hold of thees and solider them on :thumb:
Copper Fuel Pipe Lloyd Barnes DAX Technical Questions 8 23-05-07 03:58 PM
Copper Fuel Lines arowland General Tech Tips & Questions 4 28-02-05 05:48 PM
1/4 inch copper brake pipe. simon General Cobra Discussion 7 05-01-05 10:54 PM
how much PSI can Rigid copper pipe take? chris m General Tech Tips & Questions 7 19-08-04 08:40 AM
Copper Pipe David J General Tech Tips & Questions 5 28-02-03 10:29 AM
