| Clutch/Brake Adjustment I have a Tremec T500 with a Repower bell housing and 3/4" billet clutch slave, the master cylinder is a GD supplied Willwood 7/8" unit. I have just connected up the hydraulics and bled clutch/brakes. As expected the clutch is quite heavy, but it starts to bite as soon as the pedal leaves the floor. As recommended by Repower I have allowed 10mm of movement between the clutch actuating arm and the slave piston to allow for wear in the clutch. Is there any adjustment I can make at the pedal end to improve this? I have not done anything with the adjustable fork that connects to the clutch pedal. There is also quite a lot of movement in the brake pedal before the brakes start to operate, I don't think there is any air in the system as the pedal is quite firm once the brakes start to bite, it's just that I would like the bite point to be higher up without any slack. Is this just a case of adjusting the fork mechanism on the brake pedal to take up this slack? Best regards Glyn |
| Clutch adjustment | clive a brown | General Cobra Discussion | 18 | 07-01-08 10:46 PM |
| Clutch adjustment | ceejayjay | Pilgrim Sumo Technical Questions | 21 | 12-06-07 01:08 AM |
| Clutch Adjustment | SJ | DAX Technical Questions | 19 | 29-05-06 08:08 PM |
| clutch adjustment | normanh | General Tech Tips & Questions | 8 | 16-12-02 04:41 PM |
| Jag h/brake adjustment. | STOMPER | General Tech Tips & Questions | 3 | 20-06-02 01:59 PM |
