Old 24-05-05, 01:01 PM
Flexi Brake hoses for Jag Caliper - Help
Hi All
I've bought my flexi hoses with male ends. When I put them on I realised that they would obstruct the coils spring. It seems like I need a 'Banjo fitting' for the caliper side that will take the hose away from the spring.
Firstly, can I buy a BF with a female end to fit the male of the flexi? (I've heard the hoses come made up with the BF in place). Or can I use the original Jag bracket and fixed hose setup? Or make my own bracket?
What have you done?
Thanks
Gary
Old 24-05-05, 04:46 PM
Re: Flexi Brake hoses for Jag Caliper - Help
Hi Gary,
I had exactly the same problem. Bought my stainless steel hoses from Ward Engineering, which came with male bulkhead fittings on each end.
The hoses supplied are '200 series' stainless steel braided hose, Merlin Motorsports sell the banjo fittings and bolts for this series hose and the fittings swopped straight over without disturbing the compression part of the joint on the hose.
Hope this makes sense, I am assuming you have purchased stainless steel flexies.
Regards,
Neil.
Old 24-05-05, 05:18 PM
Originally Posted by NeilT
Hi Gary,
Regards,
Neil.
Thanks Neil
No I fitted rubber, a cost cutting exercise, the rubber dont have removeable ends.
I think I need a bracket of some description
ta Gary
Old 24-05-05, 07:30 PM
Club Sec/Rep Liason
I went with the AK supplied Goodrich Hoses. They came complete with angled banjo fittings, bolts, washers and locknuts. Saved a minefield of seaching
AK 427 351C T5wc
Old 24-05-05, 10:17 PM
Gary,
why not make your own bracket like I did
Pete
GD Jag, 350 Chevy, Tremec TKO
Old 25-05-05, 07:49 AM
V8bassman's Avatar
Pete,
How recent is your photograph? I notice the steering arm is not yet fitted, so you will find it will foul your copper pipe, which will need a very tight bend on it where it connects into the caliper. HTH
Dave
First Cobra - Dax (sold 2006)
Current Cobra - Hawk 289 (under construction)
Old 25-05-05, 08:34 AM
Veteran polisher.
My Jag came with the bracket for fixing the pipes.
V8bassman is right when he says you need a tight bend to miss the cast steering arm.
This is a Dax so it may be completly different to the AK and the GD.
Polishes to date = 17
Old 25-05-05, 09:36 AM
I agree, but I went to cut cost from £65 to £20. Only £45 but its starting to mount up. the only mistake I made is not knowing about the Banjo/Bracket to take the hose away from the spring. It'll not take long to make a good bracket.
Thanks for the replies
Gary
Old 26-05-05, 11:16 PM
V8Bassman,
thanks, but the GD steering arm is a modified item that goes forwards, and is already fitted in the picture - you just can't see it
Pete
Front flexi brake pipe fixing. maverick General Cobra Discussion 3 01-10-06 12:32 PM
jag flexi braided brake pipes bitsilly General Cobra Discussion 11 07-08-06 03:49 PM
Rear Flexi brake hoses (small) bc_suv Pilgrim Sumo Technical Questions 2 10-06-06 02:55 PM
Flexi brake lengths - WRONG bc_suv Pilgrim Sumo Technical Questions 11 29-05-06 10:06 AM
Flexi Brake Pipes lazyboy General Tech Tips & Questions 5 31-07-05 09:07 PM
