Old 25-05-05, 08:00 PM
kevchard's Avatar
Brake pipe
Does anyone know if the copper brake pipe has to have markings on it, or is it assumed that if it is copper, then it is suitable?
Does the same apply to copper fuel lines?
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 25-05-05, 08:23 PM
Re: Brake pipe
Hi,
I don't believe so in either case.
Mark
Old 25-05-05, 09:06 PM
Re: Brake pipe
I have copper brake and fuel lines, non marked and just passed sva :thumb:
Stan
Old 25-05-05, 09:31 PM
Banned
Re: Brake pipe
Kevin do not use copper brake pipes, they are hard and brittel. Use the type with nickle in which are soft and flexible, That apply's to petrol as well, I think they are generally know as bungie tubing any decent Auto Factor will supply you with this type Osgood :angel:
Old 25-05-05, 10:07 PM
Re: Brake pipe
Kevin
I sell Copper Brake pipe, the very pipe that Dax supply. In fact the very pipe that's fitted to 1000 Kits, Refurbs, Rollers, Astons and the like per month. The company I sell to is Automec Ltd in Buckingham (http://www.automec.co.uk). Ray Smith will sell you 90/10 CuNi, but he'll tell you that for ductility, you should use Fully Annealed C106 Copper. It does eventually work harden and become brittle as does 90/10, but is easily annealed back by heating to Cherry Red with a blow torch and quenching in water. If you speak to Ray, tell him that Dave of Cole Tubes recommended him.
My apologies to all insulted by the open advertising.
Dave R
Old 25-05-05, 10:26 PM
kurrmet's Avatar
Re: Brake pipe
Hi Kevin
Having worked with both bundy and copper pipe not only on my car but also on machines at work. I would deffinatly use copper as it is earier to work with without putting kinks into it, it will swage much better with out splitting.:thumb:
Also as Ragley said if the pipe you have is getting a little stiff one blow torch and a bucket of water and it is back to being soft as putty.:angel:
Iain West Midlands Area Rep
Dax Owner With A Huddart Engine a smile from ear to ear
Old 25-05-05, 11:26 PM
steamyrotter's Avatar
Serial Complicator
Re: Brake pipe
Hang on a mo
Just had this discussion at work.
To anneal copper shouldn't you let it cool in sand and not quench?
Queching would make it brittle wouldn't it??
Dean.
Old 26-05-05, 12:01 AM
tonym's Avatar
Disillusioned
Re: Brake pipe
I can't wait to do that to my copper fuel lines
BIG TONE
Gallery
Old 26-05-05, 12:04 AM
Serial Complicator
Re: Brake pipe
Especially if they are still full!!
Dean.
Old 26-05-05, 09:50 AM
Re: Brake pipe
'However, it is possible to cool copper fast enough to make it into a brittle material. This normally involves cooling rates of greater than 10 million degrees C per second which can only be obtained by spraying a very thin film on to a very cold surface (this equipment is very expensive).'
I think the bucket is probably ok!!
Brake Pipe/Exhaust pipe Clash martsam Engine Tech Tips & Questions 23 07-09-06 12:38 PM
Brake Pipe Options Martyn-ak427 General Cobra Discussion 4 30-07-06 08:57 PM
GD Brake pipe kit Andy302 General Tech Tips & Questions 8 21-07-06 06:30 AM
brake pipe connectors and sva markieboy General Cobra Discussion 2 29-09-05 09:15 PM
Brake pipe clips simon General Tech Tips & Questions 1 28-06-01 09:05 PM
