| Fuel filler caps Hi guys, just wondering of I buy one of these in the piccy attached (hopefully), then how do I go about fixing the filler hose to it? cheers Ben |
| Re: Fuel filler caps Ben. The filler cap is in 2 parts.The top part of the cap (the flip-up bit) itself unscrews from the flange which is the bottom bit (wide bit at bottom of pic), the flange has a stepped fitting on the underside to take fuel hose approx 2" dia. this projects about 2-3" under the wing or body.Difficult to describe, I can take some pics of mine but not `til tomorrow, somebody else may have a better description or picture. Be sure to buy one that`s sva complient, S&J motors are probably your best bet approx £160 complete Hope that helps. Tony
__________________ Cobraless again for now. But new one on order. |
| Re: Fuel filler caps My mistake Brasscraft for the cap not S&J. S&J wanted nearly £200 for same thing. Tony.
| Re: Fuel filler caps Hi Tony, wasnt too keen on the Sva caps from europa, are they the same? if not can I get some piccys please I think I know what your on about, but the flange on the one in the piccy doesnt have anything projecting downwards, it lies flat to the body, Im thinking that maybe they are to go over existing caps and I need a different flange.... Right, piccys please Tony |
| Re: Fuel filler caps Ben Will take some in the morning:thumb: . Sounds odd but I `work strange hours Should post some pics by lunchtime. Tony.
| Re: Fuel filler caps cheers mate, I'll be waiting |
| Re: Fuel filler caps correct, mine failed as it protruded more than 50mm above the surface,im sure europa still claim the very same cap to be sva compliant,but i dont know if its been changed
| Re: Fuel filler caps Ben, I had a chat with the guys at SVA reference the fuel filler cap during my test, he took great pleasure taking the p**s out of the dummy SVA kit supplied by Pilgrim which included a fuel cap that had all the sharp radii ground off, it looked naff but done the job, you may be able to get your hands on a similar one, its a key area for the test so becareful. |
| Re: Fuel filler caps Ben, I've initially gone for the Aero type flush cap to avoid all these problems. Post SVA will then be changing it for an Aston type cap. You are more than welcome to borrow the Aero cap to get you through the SVA once I've done that, probably late summer, depends when you're looking at completing. |
| Aston Filler Caps | V8 BJC | General Cobra Discussion | 15 | 27-03-07 02:14 PM |
| DAX 31/2" Filler caps (Aston Style) | madjohnny | DAX Technical Questions | 4 | 18-11-06 05:37 PM |
| Filler caps | bitsilly | General Cobra Discussion | 13 | 20-01-06 08:10 AM |
| Aero Fuel Caps | kevchard | General Cobra Discussion | 8 | 05-10-05 11:00 AM |
| SVA Unleaded Fuel restrictor for fuel filler? | BenBaron | General Cobra Discussion | 2 | 06-06-05 09:11 AM |
