Old 01-06-05, 09:14 PM
leaking rocker covers rover v8 with chevy covers
i have edelbrock chevy rocker covers fitted to my rover v8 with the aid of a pair of pop browns adapters,trouble is they leak oil.
anyone had similar problems and how have they overcome them,alternatively what have you used to seal yours so that they dont leak
cheers
russ
Old 01-06-05, 09:56 PM
Re: leaking rocker covers rover v8 with chevy covers
maybe russell ram could tell me??
Old 01-06-05, 10:07 PM
I'm not familiar with the adapter set-up, do you end up with two sets of gaskets and a metal plate?
Myles D-W
Old 01-06-05, 10:58 PM
I was considering going this route but decided it was too much potential trouble. I would fit the plates to the head with polyurethane sealer (tw*t to remove) and the rocker covers with a std gasket of whatever type. :thumb:
Stan
Old 02-06-05, 10:11 AM
the adapter plates are fixed directly to the heads so will need a good quality sealant using between them,it also helps to stick the gaskets to plate surfaces to get the correct alignment
i had trouble sealing my ford rocker covers(no comments please)and ended up sealing the gasket to the head surface to get a leak free joint
gd jag,ford 302,tremec tr3550
Old 02-06-05, 10:57 AM
russell_ram's Avatar
Club Treasurer
Russ,
I actually made my own from billet Al.
The Pop Brown ones are machined castings, if I remember correctly. Firstly are they flat? Are they porous?
Mine fitted exactly as Craigh suggests, silicon gasket to direct to head surface, std Ford cork gasket to rocker covers. Never leaked a drip.
Russ
Old 02-06-05, 03:03 PM
thanks russ
no they arent flat they are slightly bowed,but when you tighten them down they seem to fit ok,it seems like its only leaking from where the bolts hold the plate to the head.maybe the gasket sealer ive used isnt oil resistant(although it says it is)
if anyone has any other ideas,please post as i need to get this sorted on saturday,however many attempts it takes me
russ
Old 02-06-05, 03:54 PM
Hi Russ
I have exactly the same set up on a rover. I use reusable rubber gaskets(obtained from V8 tuner) sealed with silicone gasket sealant between adaptor plates and heads-Rover cork ones will do if in good nick- and similar gaskets (obtained from pop browns) between rocker covers and adaptors (not using silicone seal)
This works for me
Good luck
roger
Rocker covers for sale 350 Chevy dorian Parts for sale 18 05-12-07 04:30 PM
Chevy rocker covers. Dek Engine Tech Tips & Questions 3 19-09-06 10:20 PM
Chevy rocker covers simon General Cobra Discussion 1 16-10-04 10:34 PM
Rover V8 Rocker Covers rudy Engine Tech Tips & Questions 0 05-07-04 06:50 PM
Rover v8 rocker covers paul hurley General Cobra Discussion 3 30-04-04 03:10 PM
