| which thermostat Looking at getting a high flow stat,for my 350 but there are 3 temperature ranges 160/180/195 f. Which should I go for? cheers Mike |
| Re: which thermostat For a good functionality of an engine you should use the 180 F = 82 C the other two options are not for standard road use. You need to check also the radiator or expansion tank pressure cap, because there is a relation there. It is the pressure, temperature relation of water. 15 PSI is a normal selection in conjunction with 180 F. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Re: which thermostat thanks. i'll have a look at the cap. Mike |
| Re: which thermostat Summit Racing supplied my thermostat and expansion tank cap to match. 180F (82C) and 14 psi seems to work O.K. for me. Harry |
| Fan Thermostat | stu e | General Tech Tips & Questions | 14 | 22-09-06 08:30 AM |
| Thermostat housing | BenBaron | Engine Tech Tips & Questions | 3 | 18-09-06 04:39 PM |
| which thermostat | MR JONES | General Cobra Discussion | 5 | 31-10-05 08:07 AM |
| Thermostat | BIGUNDIES | General Tech Tips & Questions | 3 | 20-04-05 11:12 PM |
| thermostat | jeff | Engine Tech Tips & Questions | 2 | 07-10-04 01:17 PM |
