Old 11-06-05, 10:24 PM
Kelvincob's Avatar
What Oil for a T5 Gearbox
Hi Guys,
I'm fitting a B&W T5 gearbox from a GM Camaro, I don't know how old the box is but it's just been rebuilt, can anybody tell me what is the correct oil to use.
Thanks a lot.
Kelvin
Old 11-06-05, 10:52 PM
Clarkson's Avatar
Speed junkie
Re: What Oil for a T5 Gearbox
Hi,
The automatic red stuff,ATF.:thumb:
David
David
2nd baby due 23rd Jan.
Old 12-06-05, 07:25 AM
ATF is used in the world class version of the T5s but the earlier version non world class uses 75/90 gear oil.
i believe it is something to do with the bearings and lubrication.
Adrian
www.americanv8engines.co.uk
Performance V8 engine builds
Engines / rebuilds and Parts /Efi products on Evenings or
daytime on
Old 12-06-05, 07:36 AM
Club Sec/Rep Liason
ID and rebuild info etc available here http://www.5speeds.com/t5/ :thumb:
AK 427 351C T5wc
Old 13-06-05, 04:26 PM
Kelvincob's Avatar
Hi Purple AK,
That's my problem, there was no ID tags on the box so ID-ing it is hard, I'm sure it's not a WC gearbox & as I said it's been rebuilt, the tail section of the box was set at a 30deg angle so that the gearstick pointed towards the left for yank driver but I've fitted a Cossie T5 tail section which gives me a level gearbox mount, but I would like to make sure I use the correct oil in it.
Thanks to all who offered their advice.
Kelvin
Old 15-06-05, 09:14 AM
Cobra289's Avatar
Originally Posted by Kelvincob
Hi Purple AK,
Kelvin
AT the right side of the box (mid section) you will see a round casting form that indicates the year (84 or others) you can see that also at the top cover.
At the left side close to the backup switch you can read some casting number something like 13-52-065. OK the last two figures are not the correct tag of your gearbox but are close to it, so your box can be a 13-52-062.
Try at the above mentioned site this combination and you should find the year and application.
One thing is for shore:
NWC use 75W90 and WC use ATF
it is because the changes that B&W made to the synchromesh. The new ones are sintered metal instead of Bronze.
Regards,
CObra289
http://www.donostia.demon.nl
Cobra289 Gallery
Old 15-06-05, 06:21 PM
Hi,
this page should tell you all you need to know
Regards Shane GD 351W
Old 23-02-06, 09:26 AM
bert's Avatar
How much Oil for a T5 Gearbox
Hi all,
Does anyone know how much oil a WC T5 needs?
Bert
Old 23-02-06, 11:49 AM
Slightly off point but is there a difference between ATF Dexron II and ATF Dexron III. In my hurry to fill the box before the body went on I got some ATF Dexron II and filled it - it was only later that I realised that the tag on the box said III and not II. Does this matter in the T56 or are Tremec trying to do the oil companies a favour - i'm guessing III is more expensive than II as is generally the way with these things!!!
Old 23-02-06, 01:22 PM
Clarkson's Avatar
Speed junkie
Re: How much Oil for a T5 Gearbox
Originally Posted by bert
Hi all,
Bert
I put 3ltrs in mine about 2 weekago.
David
which gearbox??? Andy Badger Engine Tech Tips & Questions 4 04-10-06 01:23 PM
Oil for gearbox pat b General Cobra Discussion 2 01-09-04 11:35 AM
Gearbox ??,s Shaney23 General Tech Tips & Questions 0 10-09-03 09:48 PM
gearbox Bernie Engine Tech Tips & Questions 11 08-09-03 01:26 PM
Which Gearbox? Andy302 General Tech Tips & Questions 14 01-05-03 01:16 PM
