| Re: Self dissembling harmonic balancer-doh! I would say YES YOU NEED IT!!! Perhaps you had best look at an uprated balancer, was yours the original or a replacement? Ive just brought the FMS damper for my motor build and it looks OK. FMS-M-6316-K351 cost about £60 by the time Id imported it with my other stuff. Im unsure if you would need to get your engine balanced to suit, take further advice!
| Re: Self dissembling harmonic balancer-doh! You need it...... dont run too far without it. Have a look at a Fluidamper, no rubber bonding between the hub and outer ring to go wrong. They do a Street version which I've fitted to my 383, uses an internal vaned ring inside the damper and something like a silicon Gel to absorb the harmonic vibrations of the crank. James
__________________ Megasquirted 383 SBC built but yet to start. Dax De Dion chassis safelty in garage. Permission to spend money in March - rolling chassis here we come |
| Re: Self dissembling harmonic balancer-doh! Quote:
If no weight present then the crank is naturally balanced and you can pop on a replacement with no issues. I'm not sure whether the 302's were internal or externally balanced, I think they are internal and you'll have no problems getting a replacement. If I remember correctly the internal balance became an issue with the 400's I'm sure somone here will know and it'll become obvious when you remove the old one. James
| Re: Self dissembling harmonic balancer-doh! i think the only internally balanced sbf is the boss 302
| Re: Self dissembling harmonic balancer-doh! You need it. Damper balance is matched to the flywheel. 302s are 28oz or 52oz balance, depends on age. You will need to know which before you replace it, unless you're going to balance the whole lot again. |
| Re: Self dissembling harmonic balancer-doh! Hi Guys, Thanks for all the replies. I've found out today that 302 fords are externally balanced using front bobweight/harmonic unit, and rear flywheel. Apparently Ford went to external balance to reduce the physical size of the small block so it could be fitted in smaller vehicles. I managed to get an identical 1969 Ford used 3 bolt unit from Stateside Autoparts (on the A5 near Tamworth www.statesideauto.co.uk Tel 01827-717600) When I showed them the wrecked harmonic, they said they had never ever seen a similar failure since they started in 1973! They had seen searation where people had used a puller on the outer and pulled it off in the workshop. They'd never seen a failure like mine on the move. So I guess I was lucky!! Thanks again, Steve:thumb: :thumb: :thumb: :thumb:
| Re: Self dissembling harmonic balancer-doh! Steve, I ran an autocross a few years back and pushed the engine a little too far at one point. It probably hit 8,000 prm. I noticed water leaking from the water pump later and had to stop several times on the drive home to refill. I checked the engine for other problems, too. When I checked the timing, I couldn't get the marks to line up. The harmonic balancer had spun around. At least it didn't come off. Paul
__________________ It doesn\'t have anything on it that doesn\'t make it go faster! |
| Re: Self dissembling harmonic balancer-doh! Hi Paul, Sounds like we both had a lucky escape; the alloy aftermarket pulley stopped the cast iron outer harmonic ring going for a destructive walk around the engine bay (or out of the bonnet/through the wing-ouch!) Maybe mines been turning for a while, and finally came off, it looked like somebody had machined it off though, not one trace of the bonding rubber on either part!! Steve
| Re: Self dissembling harmonic balancer-doh! Look at the Windsor small-block forum - this is not a rare occurence with original, 30-yr-old dampers. |
| SBC Balancer / Remover / Installer | paul | The Loan Forum | 14 | 14-07-05 01:47 PM |
| Chevy Harmonic Balancer | garyholden | General Cobra Discussion | 2 | 14-09-04 07:26 PM |
| Harmonic dampers | Andy302 | General Tech Tips & Questions | 0 | 16-09-03 11:05 PM |
| Harmonic Worries!! | Warren | General Tech Tips & Questions | 6 | 27-04-03 10:46 PM |
| cracked engine balancer | miller | General Tech Tips & Questions | 2 | 10-03-02 06:54 PM |
