Old 22-06-05, 09:13 AM
Drilling stainless steel
The GD fuel tank seems to be made of the same alloy that the Terminator was made from - some sort of futuristic armour plate. I need to drill 6 holes in it to fit the fuel sender but I've already snapped one (new, quality HSS) drill bit and I think I've burnt out another bit already. Should I be using carbide bits or some sort of laser device?
Reverend Robin
GD427 Euro
World Rivnut Champion 2007
Old 22-06-05, 09:21 AM
Re: Drilling stainless steel
I doubt its made from anything esoteric. My suggestions for drilling stainless (obtained from many attempts at doing it wrong) are:
Don;t hit the hole punch too hard - just a little nick in the surface is all thats needed to locate the drill bit - an almightly dent will make drilling very difficult.
Drill a small pilot hole (1-2mm to start with), then drill the larger hole that you require.
When drilling the larger hole, use a slower drill speed, be patient, and ensure the tip doesnt get hot. Use a light oil to cool the tip. I have also used cutting compund to help along drill bits which are getting blunt...
and so lastly, and probably most important, ensure drill bits are sharp, and don;t drill fibreglass with the high quality drill bits used for drilling stainless/mild steel.
HTH
Kevin
Old 22-06-05, 09:25 AM
Already snapped my 2mm drill bit. Think I might drive up the road and buy a big pack of 4.2mm HSS bits. I'll try using a lower speed - I assume WD40 will be OK for lubrication?
Reverend Robin
GD427 Euro
Old 22-06-05, 09:30 AM
OK... that's the 1.5 bit snapped
Reverend Robin
GD427 Euro
Old 22-06-05, 09:32 AM
Get hold of a set of cobalt bits such as these :-
http://www.screwfix.com/app/sfd/cat/...10331&ts=29039
If those dont do the job then superglue might be the next resort
Old 22-06-05, 09:50 AM
you wanna see how many drill bits I got through drilling holes through my stainless engine bay cladding....I riveted every inch!!! think I went through about 200 rivets or more, probably 15 drill bits.... was sulking afterwards, during and before....
kreativejuice...
www.kreativejuice.co.uk
Old 22-06-05, 10:10 AM
God knows how GD originally drilled the large hole for the fuel sender - I'm going to head up the road to the drill bit shop...
Reverend Robin
GD427 Euro
Old 22-06-05, 10:14 AM
get some stainless steel drill bits and use some form of cooling agent, its tough stuff ,i used a squirt of wd40 now and again to help things out
gd jag,ford 302,tremec tr3550
Old 22-06-05, 10:59 AM
Blimey, they don't give away those Cobalt bits, do they? Had to buy a ten pack of normal 4.2mm bits as well as the cobalt ones only do half mil sizes
Reverend Robin
GD427 Euro
Old 22-06-05, 11:01 AM
WOW! They go through it like butter!!!
Reverend Robin
GD427 Euro
Stainless steel tubing ???? darren Pilgrim Sumo Technical Questions 9 18-08-07 04:00 PM
Polished Stainless steel windscreen zeb General Cobra Discussion 1 25-06-07 10:25 AM
Stainless steel bolts martin_t Engine Tech Tips & Questions 5 11-05-06 11:14 AM
Stainless steel expansion tank Francorchamps General Tech Tips & Questions 12 02-03-06 01:54 PM
Stainless Steel Bottles etc. BIGUNDIES General Cobra Discussion 8 23-01-06 05:23 PM
