| Oil temp sender location Hi Guys, Where is the recommended place to locate the oil temp sender? I was going to buy an adaptor to fit to the oil pressure sensor mounting hole on my Ford 351W engine just in front of the oil filter, but when I was discussing this with the Irish guy at Real Steel, he said it needed to be mounted on the oil pan to give a true temp reading. I don' really want to do this as I've got a chrome plated Ford Racing pan already fitted. What are your opinions please?
__________________ Best regards, Richard Dear GD427J0217/Mk 3 body/Ford 351W Engine Factory/TKO600/3.54PL diff/S-type narrow rear drive shafts. It's going to be red!!!! |
| Re: Oil temp sender location i have mine fitted as you say by the oil filter,had no problems with it at all,maybe a little less accurate than on the sump but that didnt bother me
| Re: Oil temp sender location Yes I also mounted mine in the oil line to the oil cooler, using an adapter from think automotive Mark |
| Re: Oil temp sender location Richard, Not sure I'd want to take the temp at the oil cooler end of things, there's a wax stat in between that and the engine....can't be a good idea? I've got mine in the sump plug, can't remember where it came from though sorry. Jim |
| Re: Oil temp sender location Drill and tap a hole in the sump plug (if its big enough) apply locktite to the threads to seal ( you dont want it vibrating loose and lose your oil over the road) screw in the temp sender. Jobs a good 'un................ Cheers, Tony
| Re: Oil temp sender location Hi, I mounted it between the waxstat and the take off plate so that it measures the temperature before the oil goes to the cooler and before the wax stat opens. Mark |
| Engine Oil Pressure Sender Location | Martyn-ak427 | Engine Tech Tips & Questions | 4 | 29-03-07 09:10 PM |
| Oil Pressure Sender location | Spanish Dave | General Tech Tips & Questions | 0 | 14-03-07 05:51 PM |
| oil temp sender | macdonaldm | Engine Tech Tips & Questions | 4 | 09-05-04 05:14 PM |
| Oil Temp sender | Ian D c | General Tech Tips & Questions | 0 | 24-04-04 09:57 PM |
| water temp sender | simon | General Tech Tips & Questions | 5 | 22-08-02 12:10 AM |
