| SBC Distributor Hi All I'm rebuilding my SBC, but I'm having a problem with the distributor. I've replaced the stock intake with a Edelbrock Performer intake and when I put the dizzy in place there is a gap of about 1cm between the intake and the dizzy seat. I checked the thickness of the intakes and they are different. Anybody come across this before? Thakns Gary |
| Re: SBC Distributor Turn the crank and it should fall in position. Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Re: SBC Distributor Thanks. In one hand I hope your right. On the other hand I look like a pr1ck. Bad day Gary |
| Re: SBC Distributor you can also do it without turning the crank.... turn the cog on the bottom of the dizzy slightly until the slot at the inside of that same cog drops into the oil pump..... when it drops in, if the engine is at TDC on number 1 piston, the rotor arm, when viewed from behind the engine, should be pointing to the number 1 piston (aka... pointing at 11:00 clock)
__________________ -------------------------------------- AK427, -------------------------------------- |
| Re: SBC Distributor Quote:
anybody any ideas please? Gary |
| Re: SBC Distributor Measure the gap with feelers and make up a spacer. You will need about 20 Thou additional clearance which should be afforded by the gasket.
__________________ All the best Paul. |
| Re: SBC Distributor All sorted now thanks |
| Distributor | harvey | Engine Tech Tips & Questions | 3 | 11-06-06 09:09 PM |
| RV8 Distributor | robinj66 | General Cobra Discussion | 0 | 04-03-06 09:57 PM |
| Wiring to a 35 DE8 distributor | David Horsnell | Engine Tech Tips & Questions | 5 | 27-12-04 09:33 PM |
| Wiring to SD1 distributor | David Horsnell | Engine Tech Tips & Questions | 2 | 08-12-04 09:24 AM |
| distributor famine !! | mike shaw | Engine Tech Tips & Questions | 0 | 07-10-04 11:24 AM |
