Old 19-07-05, 09:36 PM
Clutch setup for a T5
Folks
has any one got any advice/pictures for mounting a clutch slave cylinder to a T5. Was going to go for a Mcleod Hydraulic but after seeing recent posts decided against it. Also what would be the best size slave cylinder to go for to make the clutch pedal as light as possible. It will be going in a GD not that this should matter should it ??
Thanks
Mark
Old 19-07-05, 09:56 PM
Club Sec/Rep Liason
Re: Clutch setup for a T5
Hi Mark.
Being as the T5 (well mine anyway) came from a Mustang with cable clutch. I used a Wilwood puller slave, which basically just replaces cable and uses the original release arm and bearing. It works well with a 3/4" master to give a good, light pedal ( Liz drives it without any problem) It is also slim, so it fits in well. Sorry pic is not good, but you get the idea.
AK 427 351C T5wc
Old 19-07-05, 10:05 PM
tarmacscratcher's Avatar
There's actually nothing much wrong with a properly fitted Mcleod hydraulic throw out..........ask Dave Brookes, I had the same worries but he's fitted god knows how many and never had any comebacks.
www.betterbiker.com
Old 19-07-05, 10:23 PM
thanks for the speedy reply. I like the look of this. I think that my T5 originated from a Mustang also, the mouting lug from what I can make out looks the same as yours. From the picture I can't quite make out what the eye bolt bit needs to locate to is it the engine mounting ? Found one in the Summit catalogue but are they availlable from the UK.
Mark
Old 19-07-05, 10:27 PM
Club Sec/Rep Liason
I am in no doubt that the McCloud is a fine piece of kit when properly installed. However, logically a failed Wilwood is £45, 2 bolts and 1/2 hour to replace. Whereas the McCloud is Gearbox out, new pressure plate cos it's covered in fluid (£100) plus the cost of parts.
AK 427 351C T5wc
Old 19-07-05, 10:39 PM
Club Sec/Rep Liason
Originally Posted by rover
Mark
Mark. Rally Design sell them http://www.rallydesign.co.uk/catalog...&filter_id=597 Yes the eyebolt just locates on a bracket welded to the enginge mount (in my case) The pull rod passes through the old cable mount on the bellhousing without touching the sides ( so to speak)
AK 427 351C T5wc
Old 20-07-05, 07:18 AM
the wilwood cylinders can also be fitted with 2 eye bolt ends, i have mine with one eye bolt on the clutch fork, which i can pack out to extend the length of the release fork (if there is enough room between it and the chasis) and the other with a bracket made to fit the tko gearbox.
you can also shorten the length of the stud coming out of the slave cylinder if it helps you with location.
Adrian
Clutch Setup Martyn-ak427 General Tech Tips & Questions 3 27-08-07 09:59 PM
PCV Setup Martyn-ak427 General Tech Tips & Questions 44 18-02-07 06:33 PM
clutch slave setup Splitpin General Tech Tips & Questions 2 29-05-06 03:36 AM
Clutch Pedal Setup rich AK Technical Questions 9 10-10-05 09:33 PM
Suspension setup Bowtie AK Technical Questions 2 06-10-04 06:21 PM
