| Squeaking suspension Anyone got any tips about curing squeaking suspension? I guess there may be a 'dry joint', etc. I once read in an American magazine to mix alcohol (?) and silicone together and spray it around the suspension. When driving slowly or parking, I can hear an annoying squeak which I think is coming from the front end. Cheers..... |
| Re: Squeaking suspension i had a squeek on the front end and it turns out it was the uprated poly bushed,sprayed some motorcycle chain oil on them and hey presto no more noise russ |
| Re: Squeaking suspension The car should have its weight on the wheels before the suspension is torqued up. If it is not then the bushes etc will be under tension all the time it has weight on it and can cause squeeks and premature failure of bushes.
| Squeaking rear brakes | CycleSi | General Cobra Discussion | 7 | 06-08-07 06:19 PM |
| Squeaking rear brakes | Glyn_Turner | General Tech Tips & Questions | 5 | 01-06-06 06:39 PM |
| suspension help | steve Haygood | Newbies | 0 | 24-04-06 02:47 PM |
| squeaking powerlock diff | fcukruss | General Tech Tips & Questions | 12 | 27-07-04 06:04 PM |
| Suspension set up | James | General Cobra Discussion | 5 | 18-07-04 10:35 AM |
