| Holly woes. Hi guys, Went out today for first run since registering the beast, and it seemed to run O.K. at first ,then I got exited and floored it! next thing chugging and missing which I took to be overfueling, I opened the hood <having swithed off !>and peyrol was all over the inlet. I took the air filter off to see petrol poring out of every orifice in the carb, now! the carb is a brand new Holly 650 vacuam secondry sold and fitted by a local race mechanic?? so before I tear round and start getting shirty can I do anything myself as he is a good way off. I think it may be sticking needle valves but don't see any sight plugs or easy way into the float bowls to check or reset them? Any ideas, HELP!! GONZO. <the fuel abuser!> green I aint!! P.S.Came home via A.A. breakdown truck . <oh the shame!!> |
| Re: Holly woes. it sounds like stuck floats,im not up to speed on holleys but sounds like they may need adjusting,some of the guys on here are mustard on them,personally i would ask your race engineer about it
| Re: Holly woes. If the carb is new then take it straight back as if this was to happen again and you had a really hot engine having just had a good blast Seriously if it is new get it professionally sorted as your safety comes first :thumb:
| Re: Holly woes. Gonzo. Three possiblities. 1. Fuel pressure too high (Unlikely as it would show all the time) 2. Float levels set too high (see above) 3. Float Valve stuck/dirt in seat HTH :thumb:
| Re: Holly woes. Agree with above, the carb may have been stood for a long while. Dont despair the Holley is worth haviong for its tunability if you get it right. I assume it is coming out of the stacks, also check that the float bowl screws are tight as this is a classic on a new Holley Mike |
| Re: Holly woes. Thanks for the input guys, think I will see if the guy who fitted it can come out or recomend a course of action that won't invalidate the warranty. The only screws on the side are on the choke end ,one each side and the rest is just blank? Anyway I'ii ring him tommorow and see what he says. GONZO. < the nearly hot rodded>. |
| Re: Holly woes. Gonzo Similar thing happened to me with an Edlebrock 650 when the engine was warm - shortly after start up - switched her off for 5 mins and then she would not start so i pumped the throttle a couple of times - like you i could hear the petrol running like a tap through the carb, lifted the filter off and could see the petrol pouring down the barrels - it stopped after about 10 seconds. Not happened since - put it down to a stuck float caused by a bit of dirt which was probably flushed through. You may find it was a one off, best advise i can give is strip the carb and ensure it is clear of dirt. The Holley is a good carb so i would not be in a hurry to swop it out without considering a strip and clean. Good luck J4N
__________________ 383 Stroker power plus Anti-roll bar.....like being chained to a mad dog!! :-} There is no such thing as bravery.....only degrees of fear!! |
| Holly Help Needed | Andy S | General Tech Tips & Questions | 5 | 10-03-07 10:30 PM |
| Holly carbs | chesterak | General Tech Tips & Questions | 15 | 21-11-04 11:57 AM |
| V6 + Holly Carb | IanM | General Tech Tips & Questions | 2 | 29-06-04 10:02 AM |
| Holly Carbs | chesterak | General Tech Tips & Questions | 2 | 28-10-03 04:39 PM |
| Holly Carb | choogh | General Tech Tips & Questions | 3 | 15-12-02 10:49 AM |
