Old 28-10-05, 08:37 PM
Correct Electric Fuel pump?
Gents, I have been reading the notes on Fuel pumps in the forum
and am still confused !!!
A brief history.....
After installing my engine (Chevy 350 ci. mild tune 300-350 hp, with mechanical fuel pump) into my kit (RAM 427) I have found that the pump is far too close to the Chassis. I have therefore decided to fit an Electric fuel pump behind the rear bulkhead, in-front of the tank.
I have purchased a Facet Red top 35G/hr, which I believed to be up to the job. But after a trip to the local Engine spares shop I have been told that this will cause problems at the top end due to lack of flow, they have suggested a Holley electric fuel pump at 120G/hr & £120+vat.
Is anyone else running a similar set up with a Facet red top pump and are you having any problems? (ignoring the electrical break downs)
ie
Have I F@<£$d up again or will I get away with it ?
Comments suggestions gladly received.
Old 28-10-05, 08:46 PM
Re: Correct Electric Fuel pump?
steve
if you want to give me a ring , i can fix you up with a cheaper price on that pump
adrian
Adrian
Old 28-10-05, 08:50 PM
Miket's Avatar
Fully Paid Up Grandad
The Facet Red top won't be man enough for the job, you want a Carter performance electric pump from Real Steel. it works fine on my 350hp Chevy with a 750 Holley Carb. :thumb: :thumb:
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 28-10-05, 08:58 PM
Thanks Guys
But this is not the answer i was hoping for.
More Money down the drain......
What would be the best or should I say cheapest Pump that would work ?
Steve
Old 28-10-05, 09:02 PM
I believe the Carter is cheaper than the equivalent Holley (and is self regulating to around 5psi, so no pressure regulator needed).
Old 28-10-05, 09:18 PM
Miket's Avatar
Plus its only about £50 to £60
AK 427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Old 28-10-05, 09:34 PM
My Chryser 440 puts out 450 bhp and has absolutely no problems with a Facet red top, which has been feeding it for 4 years now. Make sure your feed lines are a decent size, and use a regulator to keep the pressure down to reasonable limits.
Old 29-10-05, 02:29 PM
Cheers..
I will have to think a little longer on weather to replace the facet with a Carter unit.
Maybe I will try getting rid of the Facet on E- bay, and recoup some readies !!
cheers again
Steve.
Old 29-10-05, 09:10 PM
Don't think - act!
Old 30-10-05, 08:07 AM
stevee8's Avatar
Steve,
If you hook up the Facet to your existing fuel lines on a temporary basis, you can disconnect at the carb and do a flow check into a fuel can.
It won't take into account any pressure losses in the carb but might give you a clue re. adequate line sizes.
Steve
Fuel Pump - Manual or Electric V8 BJC General Cobra Discussion 8 25-10-07 01:18 PM
Electric Fuel Pump Cover bogster DAX Technical Questions 25 05-12-06 01:21 AM
Where should my Electric fuel pump be located Davecw000 Pilgrim Sumo Technical Questions 9 05-05-06 03:14 PM
Chevy V8 Electric Fuel Pump bogster DAX Technical Questions 11 10-12-05 04:50 PM
Fuel Pump-Electric or mechanical? Dax SC General Tech Tips & Questions 13 05-09-02 11:39 AM
