Old 30-10-05, 08:28 AM
Fuel guage sender unit query
I have a Smiths fuel guage and a universal sender unit mounted in my tank - see attached photo.
I built my car more than ten years ago and probably fitted teh sender units sometime in 1992 during my chassis build.
Around a couple of the fitting bolts it has now started to weep very slightly when I have a full tank of fuel (as the unit is mounted near the top of the tank) so I need to remove it and refit with a new gasket and new fibre washers under the fitting bolt heads.
I have 2 questions:
1) I cannot remember how the unit is fitted and whether the attachment bolts (they actually have allen bolt heads) screw into captive nuts or a thread inside the fitting or some other way. I don't recall their being loose nuts on the inside, but I vaguely recall keeping the sender unit in position initially with a loop of string while I loosely attached the first couple of bolts - it is a long time ago...
2) Does anyone know if you can buy gaskets separately for these sender units - if not I guess I;ll have to make one out of gasket material.
Thanks in adavnce for your help/ideas.
Nigel B
Old 30-10-05, 09:07 AM
Re: Fuel guage sender unit query
Format looks Lucas universal. However I doubt if you can buy a seperate gasket. Get some cork sheet and make yourself one, using petrol resistant RTV in addition.
Mike
Old 30-10-05, 01:42 PM
Mike thanks - you are right - it is a Lucas unit. Can you recall how the retaining nuts are fitted - are they captive type?
Nigel B
Old 30-10-05, 02:39 PM
Mine are captive - but surely it depends on whose tank you have. Mine's an SS Hawk, and the captives are built into the tank.
Old 30-10-05, 10:02 PM
Clive's Avatar
If the nuts were not captive then how could you possibly fit/tighten them with the sender in place? The holes in the tank were probably tapped or self tappers were used.
Cheers, Clive
Old 30-10-05, 10:38 PM
Club Sec/Rep Liason
I resealed Plods sender unit a year or so ago. Can't remember the name of what I used but I will make a phone call and post it tororrow
AK 427 351C T5wc
Dip type fuel level sender unit. Nick S General Cobra Discussion 13 15-10-07 09:46 PM
Dax Fuel Sender Unit Problem bogster DAX Technical Questions 7 15-12-06 05:14 PM
ETB Fuel Sender Unit millmarsh Pilgrim Sumo Technical Questions 2 08-05-06 10:16 PM
fuel tank sender unit keane General Tech Tips & Questions 2 26-11-03 09:52 AM
Fuel Gauge Sender Unit VinceGledhill AK Technical Questions 1 12-03-03 01:41 PM
