Old 07-11-05, 02:28 PM
chiffer's Avatar
Oil Pressure
Started the cobra up yesterday morning, has`nt run for a week, and the oil pressure gauge took a few seconds to respond. Normally it rises to about 65lbs and when the engine is hot settles down at 50lbs per sq. in. at 1000 rpm. It first took a few seconds to move to 20lbs, stayed for a couple of seconds then moved up to 40lbs, then after a few more seconds rose to the usual 65lbs, and from then on works fine. Is there a problem with the gauge, or something more sinister?
Thanks in advance for your replies.
CHRIS
Gardner Douglas Mk3, Chevy 350, 420bhp.
Black and looks the business
Old 07-11-05, 03:34 PM
Clive's Avatar
Re: Oil Pressure
What type of guage do you have? Is it electronic or live feed? If it is electronic check wiring earth etc. If live take off the flexi pipe and check for blockages.
Cheers, Clive
Old 07-11-05, 09:21 PM
Re: Oil Pressure
Good question from Clive - if it is a mechanical gauge, it might simply be the fact that it has got colder, the oil in the capillary line will be more viscous, and the guage will respond more slowly.
Once it was running, did you notice anything else at all different?
Other thoughts - might be the anti drain valve in the oil filter has failed?
Old 07-11-05, 09:43 PM
Re: Oil Pressure
Sounds like simply a sticky gauge. Unless you have deliberately bled oil through the capillary (which I think would be a bad idea) the capillary will be mostly full of air so coupled with the friction within the gauge mechanism it is quite easy to imagine the reading lagging slightly behind what is really going on. Wilf's comment about the drain-back filter sounds interesting too, is the filter inverted on your engine?
Myles D-W
Old 07-11-05, 09:58 PM
Re: Oil Pressure
my mechanical gauge always takes a few seconds to start creeping up when the engine is started,it likes a nice steady idle to creep up to maximum
gd jag,ford 302,tremec tr3550
Old 07-11-05, 10:25 PM
Club Sec/Rep Liason
Re: Oil Pressure
My Electric gauge seems to take longer to register full pressure on startup since the temp has dropped. must be an oil thing
AK 427 351C T5wc
Old 08-11-05, 02:01 PM
chiffer's Avatar
Re: Oil Pressure
Clive.
It is electronic and sounds as if it could be a bad earth. Had a few earth problems lately.
Wilf, Mylesdw.
When the engine was fitted, the oil filter (which was replaced 200miles ago) had to be taken off the engine and replaced on the side of the body as the shassis was in the way. It is now in a vertical position.
CHRIS
Old 08-11-05, 03:11 PM
Clive's Avatar
Re: Oil Pressure
The current flows from the ignition to the guage and then to the sender through which it is earthed. Check that the sender is earthed. ie there is no sealant (loctite or PTFE tape on the threads) causing insulation between the sender & the block. I don't think that there can be a problem with the engine being earthed as you would have other problems such as temp guages, ignition, starter motor.
Cheers, Clive
Oil Pressure rick turner General Cobra Discussion 2 21-09-05 12:18 AM
Oil pressure Take-off Goldie General Tech Tips & Questions 6 07-05-05 10:25 AM
Oil Pressure marc davis Newbies 4 02-05-05 11:37 PM
No Oil Pressure !! beanpole Engine Tech Tips & Questions 4 15-07-03 12:48 AM
Oil Pressure ss083 General Tech Tips & Questions 3 23-09-02 04:40 PM
