Old 22-11-05, 04:43 PM
Alan head bolts
Anybody know where I can get stainlees allan head bolts, 4mm met. fine, with matching nyloc and washers - mail order by the weekend if possible!!
Old 22-11-05, 04:52 PM
Miket's Avatar
Fully Paid Up Grandad
Re: Alan head bolts
There was a stand opposite us at the Exeter show, what he didn't stock isn't worth having.
Spalding Fasteners Tel 01775 821233
e-mail "spaldfast@btinternet.com"
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 22-11-05, 05:15 PM
Veteran polisher.
Re: Alan head bolts
Hi Jonny
Are you asking for metric fine thread bolts. Just thought I'd ask since these are harder to get hold off.
If you require bolts and nuts stick with standard threads. I used Imperial (UNF) for 99% of my car.
Try
http://www.namrick.co.uk/
I used them for all my supplies and they usually deliver next day if you want it.
Polishes to date = 17
Old 22-11-05, 06:11 PM
Re: Alan head bolts
Craggle,
the reason I was looking at fine thread bolts, although harder to get hold of, was for fixing the pipes and cables to the chassis rails (dax de dion). With those fine threads I thought u could get more threads in the wall thickness giving a better fix.
All advice gratefully received - i'm just a novice at this!
Old 22-11-05, 06:27 PM
route66's Avatar
Tufty Club Supporter
Re: Alan head bolts
Craggle,
Use UNF or BA threads then - both have a fine pitch. Suitable taps are available.
Alternatively, use a hardened threaded hex headed self tapping fastener either bright zinc plated or stainless steel. Dax supplied me with these when I carried out the jobs you describe.
Steve
Steve -
East Anglian cobras
My Webshots photos
Le Mans 24 Hours news and forum - http://www.clubarnage.com/
Old 22-11-05, 09:03 PM
Re: Alan head bolts
Personally i'd rivnut it rather than tap it if the metals thinish.
You could try www.avonstainlessfasteners.co.uk got all my SS stuff from them, and they do mail order.
Old 22-11-05, 10:14 PM
madjohnny's Avatar
Re: Alan head bolts
I drilled & tapped my std Dax chassis with M4 & M5 for the jobs your describing and didn't have any problems using std metric threads.
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 23-11-05, 03:39 PM
Re: Alan head bolts
Margnor are also a good source for nuts and bolts and they accept any size order.
http://www.margnor.co.uk
See the build in action:
http://www.sumobuild.co.uk
Old 23-11-05, 07:53 PM
Veteran polisher.
Re: Alan head bolts
Hi Jonny
I did the same as you by drilling and tapping the chassis but used standard metric threads. M5 I think.
The chassis rails are thick enough for this and you wont be doing them up too tight anyway.
Rivnuts are great for certain jobs but they are expensive, Time consuming and ideally you need a special tool to do them up with.
Recently at work I had the opertunity to try to get a bolt out of a rivnut that was rusted in the thread. Once the rivnut starts spinning in the box section you will wish you had drilled and tapped it instead!.
V8 Head Bolts oldcobber Engine Tech Tips & Questions 10 15-01-07 11:24 AM
Head, Con Rod & Mains bolts dbm10uk Engine Tech Tips & Questions 4 27-08-06 08:11 PM
Head Stretch Bolts roger General Tech Tips & Questions 4 05-11-04 10:57 PM
Head bolts Paul B Engine Tech Tips & Questions 4 17-11-03 01:35 PM
What sealant to use on head bolts? STEVE W General Tech Tips & Questions 5 20-06-03 06:59 PM
