| Jag Front Springs Whats the general consensus on removing the front jag springs from the donor running gear. I've read the easiest way is to cut through them using oxy acetelene but I don't have access to such kit. Will I be OK attacking them with a cutting disc on an angle grinder or should I try and source a spring compressor and do it properly. Also, am I right in thnking I should be able to just unbolt the rears without any nasty surprises. Cheers Ryan
__________________ GD MKIV (yes... in black ! ) and a big box of bits |
| Re: Jag Front Springs Quote:
My oxy bottle was empty at the time so I did mine with the angle grinder without personal damage, although I strongly DON`T recommend this route as at minimum you WILL wreck the cutting disc, closely followed by fingers etc The rears are no problem.
| Re: Jag Front Springs Mine had already been but through twice each spring with a gas axe and they still went off with a tremendous bang when I unloosened the spring pan. I think the general consensous is to gas axe them. I personally would avoid going anywhere near them with an angle grinder, you'll crap yourself when they let go. God know what could happen!!!
__________________ Kev AK - 383 chevy |
| Re: Jag Front Springs The Jag engineers have very thoughtfully placed holes for this exercise. One in the centre of the spring pan at the bottom, and one in the subframe member above the top of the spring. This is to accommodate a single threaded bar (I have just done mine. Use a 3/4" dia section - I had whitworth thread to hand, but any co**** thread otherwise you'll be there all week!). This can be purchased at a builders merchant, or engineering store, and usually come in 1m lengths. You will need a minimum of 18" length! You will need min3 nuts and a couple of thick washers min1/8"-1/4"thick, and wide enough not to pull through. The top one is tricky, as it is at an angle you will need a bit of engineuity with additional metal clamped to get a level (or you may have an angled block) whichever - make sure there is still plenty of thread left. By the way - this is the third set I've done now, the very first spring shot off an tore a hole through a fibreglass car body when I used an alternative method. I was lucky I was not in the way!!!! treat these springs with utmost respect!!!! I would certainly not use any other method than this one I'm describing. This is how they are put on in the first place. Right. Cut the threaded rod to the suitable length and pass through the holes so it is inside the body of the spring. Still holding the rod, Place the angled block over the top so it sits on the subframe and then Place a thick washer on and a nut at the top to stop it falling through. This needs to be turned down the rod so there is just enough rod protruding below the bottom pan to take the thick washer/plate and two nuts. Turn one nut against the other to lock the bottom nuts together (this is so the bottom nuts remain where they are) Only the top nut turns, and not the rod. Tighten the top nut down to take up the slack, and then tighten another couple of turns to slightly compress the spring. start to undo the bottom pan bolts, just turning each a few turns at a time - they should be relatively easy to turn and the pan should stay where it is after a small gap appears - if not, turn the threaded rod top nut some more to tighten up. Eventually all the pan bolts can be removed, and then the top nut can then be slackened off. It takes some effort, so don't be surprised, there is a lot of power in these springs. As the rod is central to the spring, the pan does not go sideways - unlike those external spring compressors used in pairs!!! Keep winding the nut round, whilst checking the bottom nuts to make sure they are not coming off (you could always weld these, but it makes it more difficult to fit and remove), you'll be amazed at how long these springs are when finally tamed. Unlock the bottom nuts and remove. Ditto for the other side. The rear shock absorber/spring units can be unbolted without any compression required. Have fun Rick ---------------------------------------------------- GD427 mkIII stroked 351w TKO - pick up chassis in few weeks time. |
| Re: Jag Front Springs Cheers Rick, A very thorough and helpful explanation, many thanks :thumb: Ryan
Cheers, Tony:thumb:
| Re: Jag Front Springs I don't know if older XJ6 assemblies are the same as the my XJ40 but I copied the tool from the illustration in the Haynes manual. This consisted of a length of 20mm threaded bar with a hole cross drilled through at one end, this takes a length of 8mm high tensile steel (cut a piece from the shaft from an 8.8 bolt) that protrudes 10mm or so each side to form a T bar. This end is pushed up the centre of the spring, twisted 90 degrees then locates where the jag tool is designed to sit. At the business end I cut a section of steel tube at an angle to create the wedge and tack welded a 6mm thick plate washer to the square end. The bar passes through the washer and the spring can be compressed using a nut as per the Jag tool. You could get away without welding as the plate can't really go anywhere. Unfortunately I don't have a pic handy but the Jag manual will give you the right idea. good luck Rich |
| Sumo front springs | bluetoon | General Tech Tips & Questions | 24 | 10-01-08 11:05 PM |
| Jag Front and Rear Axle springs. | martin_t | Engine Tech Tips & Questions | 5 | 17-12-06 11:29 PM |
| Springs: which way is up? | bc_suv | General Cobra Discussion | 4 | 18-06-06 04:10 PM |
| Jag Front End Springs | Martyn-ak427 | General Tech Tips & Questions | 12 | 24-04-06 08:32 AM |
| Front springs on SRV8 | mark warren | General Cobra Discussion | 9 | 21-08-02 09:33 AM |
