| TKO II oil change How often do you need to change the oil in the gearbox ?? I've read GM synchromesh is the preferred choice for the TKO II. Also, same question re clutch and powerlock jag diff ?? Should this be done as part of routine yearly service ? Cheers in advance from 'turn key' Rob :thumb: |
| Re: TKO II oil change Hello Rob.... across the pond here the Tremec guru's suggest 100% synthetic oil be used in TKO trans.. such as Royal Purple or Red-Line synthetic trans fluid be used after 5000 or so miles put on trans. Our customers report much smoother shifts & low noise operation of trans. Change trans oil every 2 years is a safe time period.. @ average miles per year 3000 to 4000 or so. Cheers! Dr,Dee |
| Re: TKO II oil change Quote:
I have upgraded to AP 600 racing brake fluid for my new braking system as the 5.1 was overheating on the track, would it be worth changing the clutch fluid also. What fluid are people using in the powerlock diff. I know Andy B had a cooler for his diff in the racer, does anyone else have a similar application ? Cheers Rob :thumb: Official bhp figures not ready yet but fear not its gonna be >480, revs upto 6700 !!!!!! |
| Re: TKO II oil change Rob, It's worth changing the clutch fluid to the same as the brakes...if only to save a potential mix up in fluids! Rgds Jim |
| Re: TKO II oil change OK, I'll ask, how do you know if you've got brake fade (pads) or fluid boil? is there a difference in feel? Jim |
| Re: TKO II oil change Front + rear nearside bearings collapsed at Spa, which destroyed the hub and marked the disc rendering it useless:angry: . AP600 is a racing fluid but from what i understand, its hyperviscosity properties means it will need to be changed more frequently but works better at higher temps. Looking to get some ducting sorted from the front louvres which are just decorative at the moment to reduce the temperature in the front brakes. As for the feel of the brakes at high temp; situation was compounded by a mushy old master cylinder and progressive wheel wobble as the bearings became more warped. Its safe to say replacing the master cylinder with front and rears and using racing fluid may be overkill but with the engine upgrade and my heavy right foot i thought it prudent |
| Hub Change | viperjim | Viper Tech Forum | 2 | 07-11-07 11:25 PM |
| oil change | 0460richard | Engine Tech Tips & Questions | 11 | 02-03-07 11:51 PM |
| RV8 oil change | ABZV8 | Engine Tech Tips & Questions | 6 | 24-05-05 08:02 AM |
| cam change | Splitpin | General Tech Tips & Questions | 4 | 07-12-04 08:13 PM |
| Change Cam ? | MR JONES | General Tech Tips & Questions | 10 | 27-10-02 05:57 PM |
