Old 23-01-06, 11:15 PM
Rear Suspension
I am designing a front engined racing sports car using a 502ci chevy and intend using a jag rear diff.
I need rear uprights that can connect to the Jag diff and use fabricated double wishbones.
What do the various Cobras use?
Thanks for any help
Old 24-01-06, 12:00 AM
Re: Rear Suspension
Try kirkham motorsports there original spec billet uprights and driveshafts will work with jag irs diff and tubular wish bones.
www.kirkhammotorsports.com
or
www.cobraracing.com
or
concours west industries they build custom rear ends based on jag and 9" centres
Adrian
Old 24-01-06, 12:15 AM
Re: Rear Suspension
www.erareplicas.com build a custom jag based rear end for there cobra with a cast upright using tubular wishbones try them, here is a direct link to the correct web page.
www.erareplicas.com/427/frssusp.htm
Also you could weld a alloy lug to the top of the normal jag rear upright housing to form a top link pick up point it has been done before
i hope all this helps
Tell us more about your project, is this going to be some kind replica or something completely fresh?
Adrian
Old 24-01-06, 12:21 AM
Re: Rear Suspension
www.erareplicas.com/427/frsusp.htm corrected link
Adrian
also found www.cwiinc.com
Old 24-01-06, 12:38 AM
Re: Rear Suspension
These folk to a sort-of true unequal length double wishbone setup using sliding driveshafts and the original Jag upright modified for an upper pick-up point.
http://www.race-car-replicas.com/JaguarXJ13.html
That ERA version in the link above looks a bit of a hybrid; it still uses the driveshaft as the upper wishbone but adds an upper radius rod moving in quite a different axis.
Myles D-W
Old 24-01-06, 09:25 AM
Re: Rear Suspension
Thanks for all the help. I'll go look at those sites. I dont want to try the welded lug onto the jag upright, though.... not with 540hp to play with!
This is the start of a new sprint hillclimb project for me. My last car was a modprod Scimitar with the cosworth quad cam engine and very little actual scimitar left in it. Won a few championships with it.
I bought the big engine to go into a modprod corvette I was planning, but the chassis body I bought proved to have a completely knackered chassis. This left me with the option of buying a new corvette chassis or trying to rebuild the old one. Neither option was attractive so the project stalled for a coupla years.
I have long thought that the wings and aerodynamics fitted to most racing cars are basically useless unless you can set them up properly in a wind tunnel. (like building double wishbone suspension and having no idea how it should be set up). I also think that aeordynamic drag is of little consequence if u hv plenty of power and most sprints hillclimbs are pretty low speed anyway.
So.... I hv decided to build a naked 2-seater front engined chassis with no bodywork to save weight. I will use the same front suspension geomtery I used on the scimitar and add IRS with double wishbones in place of the scimitar's solid axle. Cortina front uprights will be used but I had not worked out what rear uprights to use. Now you guys have solved that little puzzle!!
Old 25-01-06, 09:43 PM
Cobra289's Avatar
Re: Rear Suspension
Nice information guys!!!
Perhaps..........
Regards,
Cobra289
http://www.donostia.demon.nl
Cobra289 Gallery
Old 26-01-06, 07:48 AM
dave's Avatar
To you, to me.
Re: Rear Suspension
GD Have a rear upright that they use on their Euro chassis that uses double unequal length wishbones.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 26-01-06, 08:17 AM
Re: Rear Suspension
and.....what about the 84 on vette rear ends,ALL ALLOY AS STOCK??!
they must be getting fairly cheap now ,as they're getting long in 't' tooth?
only a guess mind! or perhaps thats NOGOOD!???
neil
Old 30-01-06, 10:32 PM
Re: Rear Suspension
Looks like GD Euro uprights are the thing we need.
167 each... not tooo bad.
Jag diff is dirt cheap and plentiful. Blow it up... replace it real easy. The motor makes 545 bhp, so the diff is gonna suffer :-}
Rear Suspension Cobra289 DAX Technical Questions 2 20-10-05 09:33 PM
Rear suspension toe-in Pat DAX Technical Questions 4 01-07-05 08:30 AM
DAX Rear Suspension gilbeta DAX Technical Questions 0 18-04-05 02:11 PM
rear suspension set up tomdek Pilgrim Sumo Technical Questions 0 19-05-04 06:21 PM
AK rear suspension kev General Tech Tips & Questions 55 07-11-02 09:26 PM
