| Dipstick oil spray ! Just finished fitting new shiny Edelbrock rocker covers and oval air filter to the RV8 (not quite spraying). Oil is then burning on exhaust manifolds and generally creating a bl**dy mess. Any help would be appreciated as the MOT is on Saturday Cheers
__________________ Keith :-} Ignition upgraded and back on the road again |
| Re: Dipstick oil spray ! I can't see why it should suddenly need PCV when it didn't before. I would look to the new breathers and what might have changed. To push oil up the dipstick tube means there is quite some positive pressure in the crankcase. Are the new breathers more restricted than the old ones? Some of the square dragster style ones that sit on top of the rocker boxes had quite a bad reputation for being more show than go; they are too restrictive. Can't think of much else.
| Re: Dipstick oil spray ! Is there a seal on the dipstick? (Can't remember) might be worth checking that it's not got lost or nicked during the rebuild. Jim |
| Re: Dipstick oil spray ! Hi Keith, As stated by others (memory shot today) it does sound like crankcase pressure build up. The RV8 fitted with SU carbs had a hose with Y piece on one of the rocker boxes which was then connected by two hoses to a large port on each SU. No valves just direct. On the opposite rocker box to this take off, there was a small inlet port with in many cases an inline filter. Unless the engine has been standing for a long time I would say the breathers and pluming are at fault. On the other hand if your engine has stood for a while you may have a stuck piston ring. Has been known with these motors. If so it could free itself or a helping hand from a dose of Redx should do it.
__________________ Ian DAX 454 Chevy Life is short! Break the rules! Laugh uncontrollably and never regret anything that made you smile. |
| Re: Dipstick oil spray ! Thanks for all the suggestions guys, it would seem that the plumbing / breathers may be the problem and I will check that later today. The engine has only been stood for about 6 weeks so I would hope it wouldn't be a piston ring There is an O-ring seal on the dipstick and I plan on changing it just in case Martin: I had planned on fitting a PCV connected to the manifold vacuum but I've never been able to find a fitting for the manifold that would allow me to connect the pipe, any ideas ? ![]() Cheers 4 now
| Re: Dipstick oil spray ! If you have an Edelbrock carb you should have two or three Vacuum ports on the front of the carb. One of them should be connected to the PCV, can't remember which one off hand. It does matter which one or you can get too much vacuum. One of them also goes to the vac on the dizzy.
| Re: Dipstick oil spray ! I had a similar problem with the std SD1 tube and stick - the inverted bell cover did not seal. My engine is built as new so there is (should not be) no blow by, it seems a characteristic of the RV8 that the cranc case pressure will push oil up the tube. I have fitted a Discivery tube and stick - no more oil leaks - at least not from there!!! BTW, I have fitted a PCV on one rocker cover, seems to work OK.
__________________ Stan |
| Re: Dipstick oil spray ! Ordered PCV which will hopefully sort the problem out, watch this space Thanks again
| Dipstick denied.. | runt | General Cobra Discussion | 4 | 16-09-07 06:38 PM |
| Dipstick insertion...!?! | runt | Engine Tech Tips & Questions | 8 | 26-02-07 09:20 PM |
| Dipstick Location | Martyn-ak427 | AK Technical Questions | 4 | 08-02-07 11:54 PM |
| Dipstick Issue | mikey | General Tech Tips & Questions | 4 | 01-08-04 09:58 PM |
| Broken Dipstick | Ian D c | General Tech Tips & Questions | 8 | 19-02-04 10:58 PM |
