| Re: Fuel pump problem? Well I guess if the pump stops occasionally it is more likely to be a wiring problem. What did you need to do to get it going again? Is your pump wired through any sort of safety cut-out, inertia switch, oil pressure switch? Does it coincide with something else, maybe the fans coming on? I have run Holley red tops for a good many years and have not come across any reliability problems with them.
| Re: Fuel pump problem? Thanx Myles I have a cut out switch but tested this and seems ok. Does not seem to be related to any conflicting circuits. J
__________________ 383 Stroker power plus Anti-roll bar.....like being chained to a mad dog!! :-} There is no such thing as bravery.....only degrees of fear!! |
| Re: Fuel pump problem? Is your fuel pump wired through an oil pressure switch? Sometimes done to stop the fuel pump from running after an accident. Not a bad idea, really. Might be something else to check. Can you temporarily fit a light from the "hot" (+ve) side of the fuel pump and earth, visible in the cockpit? If the light goes out, power has been lost to the pump, therefore wiring/relay fault. If the light stays on, yet the pump stops, earth or pump fault. Edit - oops, just saw that Myles had covered the oil pressure switch thing already.
| Re: Fuel pump problem? Can't think what else to suggest. The Holley is a very simple beast; the two wires on the top of the pump simply join by two short links to the motor brushes. There's nothing much to go wrong, especially intermittently. It is quite simple to take it apart but a little tricky to get back together (you need some little ty-wraps to hold the brushes in during assembly). Are you sure it is actually stopping? another thought is that the built in pressure relief valve is sticking occasionally.
| Re: Fuel pump problem? hi this pump couldn't be running hot/overheating .... or is there any restriction on the inlet side or fuel pipe collapsing..... ie do you have a good thick wall rubber pipe,or lack of air getting in the tank....just a few reasons perhaps ... i had a 'problem in saudi with my 'vette....finally traced to a trapped fuel line (pinched between a tank securing strap and tank body...!) it took perhaps 2 weeks of messing about and it wasn't till i dropped the tank (all with not many tools!) that i stumbled across the real problem! DOH!!! after checking for air leaks, fuel blockages, restrictions etc .... hope it 's simple to find...! all the best NEIL |
| Re: Fuel pump problem? James. I had exactly the same sort of thing. It turned out to be dust/crap that had accumulated in the tank during the build period blocking the filter in the pump and causing low pressure. I cleaned it out and fitted a new filter between the tank and the pump and it's been ok ever since. As a test, remove the outlet hose from the pump and run a hose from the pump into a jerry can. It should pump about 70 gals per hour. Mine was a trickle
| Re: Fuel pump problem? thanx guys - some really good pointers there. Will check all at at w/e cheers J ![]()
| Problem with oil pump stripped thread | BenBaron | General Tech Tips & Questions | 1 | 18-06-06 03:32 AM |
| fuel pump | lordy | Pilgrim Sumo Technical Questions | 13 | 12-08-05 11:06 AM |
| new fuel pump | MARTIN123 | General Tech Tips & Questions | 1 | 21-01-05 04:10 PM |
| Fuel Pump Problem | Goldie | General Tech Tips & Questions | 12 | 30-08-04 09:01 PM |
| Fuel Injection fuel pump problem. | Poohbear | Engine Tech Tips & Questions | 20 | 11-05-04 10:53 AM |
