Old 12-04-06, 11:13 PM
bogster's Avatar
Mcleod Slave Cylinder Bracket
Hi,
Just finished making my slave cylinder bracket. I've got a 7/8" Mcleod slave cylinder and TK0 500 scattershield. No one had a bracket to fit it anywhere so I've had to make it. Glad I bought the welder now!
The side of the scattershield had a bracket mount which I have used. A bit tricky as the bracket had to be offset to run flush with the slave cylinder. It's well clear of the exhaust manifold pipe and inset from the chassis rail. Just have to drop it into the powder coating chap to finish it off.
A productive evening at last!
If anyone is planning for a similar gearbox/scattershield setup then I'll be glad to give you the dimensions for the bracket. I've attached a couple of pictures.
Bogster
Live the Dream
Old 12-04-06, 11:26 PM
Miket's Avatar
Fully Paid Up Grandad
Re: Mcleod Slave Cylinder Bracket
Nice job, you could also ues the threaded holes in the block.
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 12-04-06, 11:37 PM
bogster's Avatar
Thanks Mike
I wanted to keep well clear of that area as I wasn't sure if the rear header pipe might clash with the bracket. I've used 5mm steel for rigidity so the bracket is solid.
Bogster
Live the Dream
Old 13-04-06, 04:34 PM
skorpion's Avatar
Hi Bogster,
That slave cylinder looks like one of CNC. Exact the same shape and fittings are included. Watch out for that 90 fitting, the material is soo soft, while screwing in an adapter, the complete fitting was split into 2 pieces before I noticed. (this is holding me up at the moment)
Watch out for heat or try to make a heatshield for the slave cylinder. A friend of mine is going to make a shield because he has problems with the heat here.
Strange indeed, everybody needs to make it's own bracket but it is a rewarding activity
Regards,
Andy
Dax Tojeiro de Dion
http://users.telenet.be/cobra427/
Old 13-04-06, 04:36 PM
bogster's Avatar
Skorpion,
Can you tell me what type of fitting that 90 degree elbow is coming out of the slave cylinder? Who do you think makes it?
thanks
Bogster
Live the Dream
Old 13-04-06, 06:47 PM
skorpion's Avatar
Hi Bogster,
I mean with that elbow actually the thing which sits at the bottom rear of the slave cylinder on your slave-cylinder-bracket-1.jpg
Look at attachment....
I have no idea who really makes them...
You could also considered the wilwood slave cylinder which is a pull type with a long stroke.
Regards,
Andy
Dax Tojeiro de Dion
Old 13-04-06, 07:10 PM
bogster's Avatar
Andy,
why would I want a pull type slave cylinder when I've just spent an evening making a bracket for a push type slave cylinder? I'm content with the slave cylinder I've got, thanks anyway.
I was only asking if you knew what type of brass fitting that elbow was. It has a convex profile at the bottom of the 3/8" UNF internal thread. It seems as though it is designed to mate with a bolt that has a concave end.
Bogster
Live the Dream
Old 13-04-06, 07:32 PM
dingocooke's Avatar
Take the brass one round to any industrial hydraulics company and get a steel one, most hydraulics suppliers will be able to match it up for you.
If it was me, I'd then chuck the brass job in the bin!!
Looking good!
Steve
Steve
We're here for a good time...
Old 14-04-06, 02:30 PM
skorpion's Avatar
Hi Bogster,
about the pull type...was just in case your current setup hasn't enough stroke or you want to change the slave because the clutch is too heavy.
Because you made the slave on the end of the fork, I think you need a lot of stroke and/or the clutch is heavy.
What is your master cylinder bore & stroke ?
What is the length of the fork at the clutch (at which length does it pivot) ?
With this I can estimate/calculate the pedalforce needed...
Regards,
Andy
Dax Tojeiro de Dion
Old 15-04-06, 06:05 PM
Dax SC's Avatar
Good work Bogster!
I spent a day last week fabricating a bracket to weld to my Lakewood scattershield. The slave cylinder pushes from the engine side. Dropped the engine/trans in yesterday-bugger! - the slave cylinder hits the chasis rail. So now I will need a puller slave from the transmission side (where there is loads of room). Oh well, you live and learn!
Mark Smith
RV8 Slave Cylinder TINKA General Tech Tips & Questions 4 16-05-05 06:09 PM
Slave Cylinder & Mounting Bracket bogster DAX Technical Questions 9 13-05-05 08:34 PM
Slave cylinder bw41059 General Tech Tips & Questions 3 30-04-04 04:03 PM
SLAVE CYLINDER bw41059 General Tech Tips & Questions 3 30-04-04 11:05 AM
7/8" SLAVE CYLINDER bw41059 General Tech Tips & Questions 8 06-04-04 10:51 AM
