| Another clutch travel query Hello all Having put together the clutch system I could not get the the clutch to release. After many joyful hours of taking things apart and putting back together again ity became obvious that there was not enough travel on the slave cylinder. Present setup is Girling 3/4 master cylinder 35mm stroke on Dax pedal box Girling 3/4 slave cylinder on Lakewood centre pivot arm giving 25mm stroke. Unfortunately at least 33mm stroke is needed to release the clutch Having used the search it appears that others have had similiar problems but with unclear answers. Would a 7/8 master give more travel but be unacceptably heavy? (current set is just about tolerable). Are there any other 3/4 slaves available to give more stroke? A stalled cobra builder would be grateful for any suggestions. Thanks DH |
| Re: Another clutch travel query Hi DH, Knowledge is power so...it's not rocketscience.... http://users.telenet.be/cobra427/clutch.html If you give me your constants/dimensions as shown in excel sheet, light yellow cells, I can calculate for you pedal force and whether it will work or not. I had to reduce the fork length in order to get the stroke on the clutch. Regards, Andy |
| Re: Another clutch travel query If you decide to go the larger master route I have one for sale Cost £96 all I want is £35. Which ever way you go larger master or smaller slave the pedal weight will go up the same amount.
| Re: Another clutch travel query Thanks all - I think I will have to go down to a smaller diameter slave . Andy - are you able to calculate what the stroke would be with say a 5/8 slave? Va (slave to pivot) 175mm Vb (pivot to thrust bearing) 75mm angle 110 master 3/4 stroke 35mm slave 5/8 stroke ? DH |
| Re: Another clutch travel query Quote:
Sorry I forgot all about it i will have a look and post in about an hour
| Re: Another clutch travel query Thanks mate. Any pics??
but it is a 1" master
| Sumo clutch pedal travel | Don347 | Pilgrim Sumo Technical Questions | 13 | 03-11-07 09:44 PM |
| Silent Travel Locks | pelham939 | Parts for sale | 7 | 28-09-07 12:44 PM |
| Brake Pedal Travel | v8robert | General Tech Tips & Questions | 5 | 14-07-05 02:41 PM |
| Brake travel | Miket | AK Technical Questions | 3 | 14-06-04 09:45 PM |
| Small Block Chevy with Tremec Clutch Arm Query | wilf | General Tech Tips & Questions | 3 | 07-11-02 08:25 PM |
