Old 23-04-06, 08:29 AM
Jag Front End Springs
Hi Guys,
Just to let you know I have "dropped my cherry" with regards to cutting throught the original jag suspension front end springs & am pleased to tell you I didnt suffer any damage to person or property!!
As I dont have oxy-acetylene cutting gear I very carefully cut halfway through each spring with a grinderette while wearing adequte levels of person protective equipment, I then give each spring a firm tw*ting with a 7lb persuader & hey presto spring tension no more!
I do not endorse this highly technical method but it seemed to be the safest & most effective!!
Regards,
Martyn
Old 23-04-06, 09:03 AM
Dutch Paul's Avatar
Re: Jag Front End Springs
Originally Posted by Martyn-ak427
Hi Guys,
Regards,
Martyn
It worked for me that way, but like you say a "little" dangerous.
Just make sure ALL the compression is gone before going any further. I seem to remember I had to cut one of my springs twice as it caught up and didn`t fully relax the pressure.
Old 23-04-06, 02:48 PM
RobinH's Avatar
The scrappies do the gas-axe thing for the fun of it I think. A much more controlled way is to make yourself a compressor with a length of 12mm studding a few nuts and a couple of large washers or larger metal plates with holes in. You can then put this through the middle of the spring as per the Jag tool and then release it all down in a controlled way. I welded one nut to the end of the stud bar so I could even wind it in and out with the air-driven wrench.
Robin
AK427 sporadically in a state of build.
Old 23-04-06, 07:59 PM
kayjayd's Avatar
Hi Guys,
Regards,
Martyn
I agree with Paul. When you take the bottom shock plate off still take care. Mine were cut through in two places with a gas axe and still went off with one hell of a bang when I took the shock plate off -nearly followed through!!!
Kev
AK - 383 chevy
Old 23-04-06, 08:04 PM
madjohnny's Avatar
I didn't even realise they were under tension..........................frightened the living daylights out of me!!!
Shattered the cutting disc on the grinder and slammed into the garage door!!!
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 23-04-06, 09:20 PM
Dutch Paul's Avatar
I still don`t have full use of my ring finger on my right hand (after 18months) from stripping the jag. It wasn`t from the springs though - that`s another story
Old 23-04-06, 09:50 PM
madjohnny's Avatar
Probably best keep that to yourself!
Cheers, John.
MJ's Gallery
Old 23-04-06, 09:55 PM
Club Sec/Rep Liason
Too Much Info
AK 427 351C T5wc
Old 23-04-06, 10:08 PM
nearly thers's Avatar
I don't have full use of my ring finger since the ring went on it!!! It will no longer reach in my wallet as there is nothing in there anymore and it wont work the remote control as that is no longer in my possesion!
Guess that's life, you're probably at less risk with a gas axe and a coiled spring rather than taking on a mother in law!
Neil
I should be called "Nearly There" But I was drunk when I joined this club!
Old 23-04-06, 10:46 PM
Dutch Paul's Avatar
I guess I could have worded that better
Sumo front springs bluetoon General Tech Tips & Questions 24 10-01-08 11:05 PM
Jag Front and Rear Axle springs. martin_t Engine Tech Tips & Questions 5 17-12-06 11:29 PM
Springs: which way is up? bc_suv General Cobra Discussion 4 18-06-06 04:10 PM
Jag Front Springs ryan General Tech Tips & Questions 7 05-12-05 01:57 PM
Front springs on SRV8 mark warren General Cobra Discussion 9 21-08-02 09:33 AM
