Old 02-05-06, 10:57 AM
Water temp sender
Does anyone know where the temperature sender unit goes on the Ford 351W engine? If they do, do you know what the thread size for the adapter is?
Thanks.
Old 02-05-06, 02:17 PM
rich's Avatar
Re: Water temp sender
Hi Jon, It can go in the intake manifold or in certain types of thermostat housing,if you have opening above the main pipe.
If you have an Edlebrock manifold it will be a NPT fitting here's a chart to identify the size as these fittings a complicated to measure
American pipe thread NPT (conical)
  • NPT Fitting.... Thread-Ø mm
  • 1/8"NPT ..............10.2
  • 1/4"NPT ..............13.7
  • 3/8"NPT ..............17.1
  • 1/2"NPT ..............21.3
  • 3/4"NPT ..............26.6
  • 1"NPT .................33.4
  • 1 1/4"NPT ...........42.1
HTH
Rich
You know it makes sense
rich.
All Things Cobra.Com
the cobra builders resource
Old 02-05-06, 02:46 PM
dingocooke's Avatar
On the edelbrock manifold its behind the thermostat housing, NPT as Rich says
Steve
We're here for a good time...
Old 02-05-06, 02:48 PM
Thanks AK.
We have the edelbrock performer manifold. I had a look last night and couldn't see where the sender could go. The only possible place seems to be a plug on the offside, just behind the carb. However, that seems to go into one of the inlet chambers rather than a water jacket. Any ideas??
cheers
Old 02-05-06, 02:50 PM
Steve,
is it possible that the take off for the water heater has been put in the water temp sender hole? There is a pipe tail, in pretty much the position that you suggest.
Old 02-05-06, 02:56 PM
rich's Avatar
There should be another plug/hole across from the heater take off,
as you say the one at the rear is for your servo vacuum.
If you still cant find it I'll try and get a piccy.
rich.
Old 02-05-06, 03:02 PM
dingocooke's Avatar
See Pic hope this helps?
Steve
Old 02-05-06, 03:03 PM
rich's Avatar
Heres a piccy, I had to move the coil on my Engine Factory supplied 351 to get to the plug
rich.
Old 02-05-06, 03:09 PM
dingocooke's Avatar
On my set up thats the heater return, but it doesnt matter which you use really, although near the stat is more useful for temp indication???????
Steve
rich's Avatar
well now you have two options, the one that Dingocooke is showing is where my heater return is, where have you returned yours Dingo'?
EDIT
we'll have to stop overlapping these posts, its getting confusing
rich.
Water Temp Sender Problem BenBaron General Tech Tips & Questions 4 15-06-06 09:19 AM
Water temp sender. tony General Tech Tips & Questions 3 02-03-05 05:31 PM
water temp sender thread craigh Engine Tech Tips & Questions 0 19-06-04 02:10 PM
Water temp. gauge/sender question ian General Tech Tips & Questions 6 31-07-03 10:21 PM
water temp sender simon General Tech Tips & Questions 5 22-08-02 12:10 AM
