| differential I have picked up a new ford 7.5" scorpio v6 diff to replace my existing diff,but i did not realise that the output flanges are bigger (110mm instead of 100mm i think)can anyone please tell me if i can swap these from one diff to the other and if so is it difficult.p.s. is the propshaft flange the same cheers |
| Re: differential someone somewhere must know please |
| Re: differential Help please im stuck |
| Re: differential As Kev said if you are changing a sierra diff to a granada one then changing the rear running gear will give you some problems -ie Handbrake cable And the worst one will be the hubs of the granada are five stud not four stud as the sierra ones, thus you will have to change the wheels too !
__________________ Cheers !! Terry If It Ain't Broke Don't Fix It !! www.topclassphotographics.co.uk |
| Re: differential I've dragged my diff out today which is a 7.5" Granada Scorpio. The output shaft flanges are 100mm (101mm to be exact). It sounds as if you are having similar problems to me so if you'd like to PM me (handjgilbert@aol.com) we may be able to help each other. Harry |
| Re: differential www.interford.co.uk forums are a good source of ford info. If you go on the sierra forum they are a lot more active than the granada one. I am sure that 'madoldbugger' might be able to come up with a solution. Good luck. Cheers
| Re: differential managed to sort problem today, I already had a Granada 7.5" diff fitted to the car, I wanted a lower ratio so managed to get Scorpio diff that had a lower ratio but it had 108mm output flanges, which the later Scorpio had but managed to take these flanges out and swoped them with the original diff - so problem sorted. |
| XJ6 differential | Marc | General Tech Tips & Questions | 3 | 30-07-07 11:08 AM |
| Differential ID | Orange Cobra | General Tech Tips & Questions | 7 | 06-09-06 10:36 PM |
| Jaguar Differential | tonyevans | General Cobra Discussion | 1 | 22-02-04 08:43 PM |
| V8 XJ8 Differential - any use? | jonbillings | General Tech Tips & Questions | 6 | 15-10-03 02:14 PM |
| Which differential? | MR JONES | General Tech Tips & Questions | 3 | 11-01-02 01:39 PM |
