Old 14-05-06, 01:07 PM
Vacuum Hose / Fuel Hose
Hi all,
I currently have all my vacuum hoses mocked up with fuel hose of the correct internal diameter.
Should I be aiming to replace these with vacuum hose or will fuel hose suffice? What is the difference between the two?
Thank in advance,
If only life was as kind to me as my wife is....
Old 14-05-06, 03:57 PM
Re: Vacuum Hose / Fuel Hose
Vacuum hoses have much much thicker walls so they don't collapse under the vacuum pressure. You will have to replace the fuel hoses on there.
See the build in action:
http://www.sumobuild.co.uk
Old 15-05-06, 11:16 AM
Hi Brian
I used normal fuel hose for vacuum pipes (servo and feed to PCV) and stopped it from collapsing by putting 8mm copper fuel pipe inside the rubber fuel hose . The benefit is you can bend it to where you want it to go and stainless braiding and end finishers fit nicely on the rubber pipe. Works a treat
Keith
:-} Ignition upgraded and back on the road again
Old 15-05-06, 11:43 AM
dave's Avatar
To you, to me.
Originally Posted by Jake
Hi Brian
But if it's attached to the engine at one end and the servo/body at the other then fatigue will set in and eventually break the copper, that's why you should use vac hose.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 19-05-06, 03:49 PM
Dave
The copper pipe isn't actually connected at either end, it stops just short inside each end of the rubber pipe but does stop collapsing of the pipe. The advantage for me was that I could bend it around and it stayed in the correct palce without need P-clips etc.
Keith
Old 21-05-06, 12:28 PM
Thanks Jake, great tip!
Silicon vacuum hose lomondbob DAX Technical Questions 12 28-10-07 06:06 PM
Vacuum Hose route lomondbob DAX Technical Questions 3 17-09-07 07:36 PM
Fuel hose SVA keane General Tech Tips & Questions 11 26-05-07 05:12 AM
Vacuum hose JonnyT DAX Technical Questions 9 15-01-07 05:27 PM
Vacuum Hose Question Goldie General Tech Tips & Questions 2 17-05-05 05:51 PM
