| Re: Thats broken it!!! HELP I think that I am repeating what has been said already to an extent - be very careful with easiouts - I have tried using them (high quality and expensive ones) on about three occassions each time - despite doing everything by the book, drilling, heating, etc, I have had no luck and snapped them off - fortunately on two occassions there was just enough left to chisel the easiout round the wrong way to free it - the thrid fortunately was on a small part and I ended up getting another. The easiest way, as has been said is to take the manifold off and see if there is a bit sticking up - in my limited experience, there usually is, and even if not enough to get grips on, you can always use a fine chisel on the bit that is left to very gently loosen it and then a pair of pliers will do it - surprising how easy this is with a little care and patience. An alternative - and you have to be VERY careful with this is to drill out the remains to tapping size and retap the hole - you have to drill dead centre of the hole, then pick with a very fine screwdriver the first few threads away (sometimes you can get the whole lot - but it is unusual), and then, using a taper tap, retap the hole, clearing the swarf as you go. I am not however sure I would be brave enough to attempt this in such an important spot. Best of luck with that - but try option 1 first - u may be pleasantly surprised. Fingers crossed Jon
| Re: Thats broken it!!! Now its Fixed!! Hi Well after removing the manifold the stud came out with just a set of pliers,to say I was pleased would be an understatement. Manifold is now back on,carb fitted and starting to plumb in So the car cover will stay off for a while yet!! Cheers for all the replies Steve
__________________ Regards Steve Fawlty:drive: When will it ever be finished??!! |
| I've Broken the Law! | Simon R | General Cobra Discussion | 15 | 18-10-07 07:48 PM |
| Thats broken it!! HELP! | MrFawlty | Pilgrim Sumo Technical Questions | 17 | 25-05-06 01:30 PM |
| Silence Broken!!! | Novacatt | Pilgrim Sumo Technical Questions | 2 | 17-05-06 03:40 PM |
| Broken Piston (I think) | jenny | General Cobra Discussion | 12 | 04-05-06 05:48 PM |
| Broken it already | andybrown | General Tech Tips & Questions | 5 | 13-09-03 12:07 AM |
