| Thats broken it!!! HELP Have just posted this under Sumo questions but should have put it here Hi all, Well,after finally getting some time to fit my new edelbrock manifold(pilgrim sumo,RV So the question is what do I do now.I have heard of a tool that screws in anti-clocwise and draws the stud out,is this the best route to go or is there anything else. Please don"t tell me the engine has to come out Also I have noticed the carb will not be level,engine too low or gearbox too high,seems like I need a levelling plate but I don"t think other builders have had to do this, I feel like throwing the cover over the thing for a few months Thanks Steve
__________________ Regards Steve Fawlty:drive: When will it ever be finished??!! |
| Re: Thats broken it!!! HELP Hi again, Forgot to say I bought the bolts from a "bolt shop!" and I wonder if they are the correct ones,were they too soft Is there a particular type for this application Steve
| Re: Thats broken it!!! HELP thanks for the info Neil.I will source one and try that FINGERS CROSSED cheers Steve
| Re: Thats broken it!!! HELP or take the manifold back off, and hopefully there might be the shank of the sheared bolt you can put mole grips on and wind it out; I have managed this on more than one occasion. Good luck and take it very slowly!! Steve
__________________ Regards Steve-serial cobra buyer; is it an illness??? We're not here for a long time, We're here for a good time... |
| Re: Thats broken it!!! HELP Machine Mart do a 4 piece Stud extractor set which appears to work without need for drilling. Order Code is040210057. Alternatively they do "Irwin Bolt Grip" sets if you still have a head on yours (again no drilling). I have a levelling plate on my RV8 - try www.v8tuner.co.uk or Real Steel. I ended up using stainless steel manifold bolts from one of the above.
| Re: Thats broken it!!! HELP FWIW Re the above post. If you manage to break an easyout/tap etc in a hole all is not lost. Try smashing it into smaller pieces using a hammer and dot punch(wear glasses as the bits will fly about a bit)Taps and easyouts are, although hard, very brittle. Then you can "pick" the pieces out with a piece of thin, strong wire. This has always worked for me in the past.
| Re: Thats broken it!!! HELP Make sure you are buying / using Grade 8 bolts. ( Common automotive SAE Grade ) Many nuts & bolts sold at various outlets are of a much inferior strength for use on vehicles etc. The correct ones should be marked with an '8' usually on one of the flats of the bolt head. Hope this helps,
__________________ Roger Magnum MkI Still looking for the Last Open Road ! ! ! |
| Re: Thats broken it!!! HELP Steve, As Neil says, be very careful with easiouts, they shear very easily if the stud is tight. Gripping anything that is left protruding would be preferable along with applying heat to the surrounding material if you can. Good luck. Alan
__________________ Sumo - 302Windsor - Tremec TR3550 SVA Passed, Registration here and on the road......yeehaa! Now where\'s the sun? |
| Re: Thats broken it!!! HELP Hi all, Thanks for the replies I will let you know how it goes Its a real pain having to do a job twice as I get so little time to work on the Cob anyway,such is life It could be worse I could be driving a Metro!! Steve
| I've Broken the Law! | Simon R | General Cobra Discussion | 15 | 18-10-07 06:48 PM |
| Thats broken it!! HELP! | MrFawlty | Pilgrim Sumo Technical Questions | 17 | 25-05-06 12:30 PM |
| Silence Broken!!! | Novacatt | Pilgrim Sumo Technical Questions | 2 | 17-05-06 02:40 PM |
| Broken Piston (I think) | jenny | General Cobra Discussion | 12 | 04-05-06 04:48 PM |
| Broken it already | andybrown | General Tech Tips & Questions | 5 | 12-09-03 11:07 PM |
