| GD Rear O/S Wheel clearance I've heard the GD shell, having been taken from a hand built original or a copy of one at least, is somewhat asymetric around the rear arches. Having just dropped my suspension by an inch or so the rear o/s wheel is now catching on the top/front of the arch and scagging the ally arch cover. (It did before but only under extreme provocation)I've got standard wheels , tyres etc all sourced from GD, so has anyone else had this or am i , err.. 'special' Only thing i can see to do is grind the arch return back and fold the ally cover in a bit. This is what it looked like before i lowered things.. (You can see the ally is slightly bent at the top) ![]()
| Re: GD Rear O/S Wheel clearance i had this problem and ended up using the trusty dremel to grind away the problem area,it wasnt much but it was the only way i could stop the fouling
| Re: GD Rear O/S Wheel clearance Looks like i need to do a Creffield Special then, now where's my grinder.
| Tyres and wheel arch clearance | qkingston | General Tech Tips & Questions | 1 | 08-11-07 05:17 PM |
| Rear wheel arches | JonnyT | DAX Technical Questions | 9 | 22-01-07 04:09 PM |
| Rear wheel arch - something is not right ! | hadi | AK Technical Questions | 4 | 10-07-05 05:45 PM |
| Another Dax Question! - wheel clearance. | martin | DAX Technical Questions | 12 | 03-05-03 11:47 AM |
| MKII Sumo Rear Wheel Ride Height/Arch Clearance | Mike H | Pilgrim Sumo Technical Questions | 7 | 28-02-03 06:51 PM |
