| Jag diff rear cover seal Hi Guys, I have now tried to seal the rear cover plate on my Jag diff 3 times and I still get a slight weep. And this is whilst it's still in the garage and not subjected to road use. I've twice sealed it with black RTV, cleaning both surfaces with acetone and the last time I bought an original paper gasket and applied RTV to both sides. Still a weep and it is always at the bottom. The cover plate looks pretty straight but when I take it off next time I will put a straight edge across it but I would expect the RTV to fill any gaps. Am I tightening the bolts too tight and squeezing all the RTV out. Should I partially tighten and then finally tighten once the RTV has cured? Any other thoughts or ideas???
__________________ Best regards, Richard Dear GD427J0217/Mk 3 body/Ford 351W Engine Factory/TKO600/3.54PL diff/S-type narrow rear drive shafts. It's going to be red!!!! |
| Re: Jag diff rear cover seal Hi Richard, Make sure you tighten the bolts gradually and in opposite diagonals (ie top left, bottom right, top right, bottom left etc) Cheers, Clive
| Re: Jag diff rear cover seal Hi Kevin, It's definitely coming from the bottom edge of the cover. I have kept an eye on it for several weeks and kept wiping with clean kitchen roll. The diff is clean and powder coated so it is easy to spot weeps. Hi Wilf, Unfortunately it is still in chassis build and has not been run in anger. This is why I'm a bit concerned as what is going to happen once it gets warmed up with power going through it? Previously I have used the small tubes of Halfords RTV, going off down the Motorfactors and buying the bigger tube to fit a mastic gun I have. This should put a decent bead all around. I'll let you know how I get on.
| Re: Jag diff rear cover seal Richard I had the same problem also. In the end I used a polyurethane sealant (sikoflex) and it doesn't leak any more. Sticks like **** to a blanket that stuff:thumb: . The above advise will make the seal much more efficent. Good luck. After leaking for a second time with only the lightest of hylomar as a seal I now dread looking under the car everytime I enter the garage. 6 months on and it aint leaking doubt it will ....... until I get it on the road and can't get to it anymore Good luck,
__________________ Lee Gardner Douglas Mk4, Ford 351C, TKO600, 3.31 LSD, Sidepipes, 15" wheels. Black, basic and buisness like. My car pics |
| Re: Jag diff rear cover seal Hi Lee, Is Silkoflex a trade name? Do you get it from a Car shop or Builders merchant?
| Re: Jag diff rear cover seal Richard, Sikoflex is a trade name but it's basically RTV. A 3-4 mm bead should do it. It's worth circling the bolt holes too as well as the main cover ring.
| Re: Jag diff rear cover seal Hi Guys, I've just found a tube of Loctite 598 black silicon flange sealant in the back of the workshop so I'm going to give this a go tomorrow. As you suggested Kev, a good healthy bead and around the bolt fixings. I think I will just hand tighten until it has gone off and then finally nip up with a spanner once it is dry. I'll let you know how I get on.
| Ford front cover crank seal question. | Andy302 | General Tech Tips & Questions | 2 | 07-05-06 10:17 PM |
| Changing the pinion oil seal on Jag diff | kayjayd | General Cobra Discussion | 2 | 18-10-05 09:35 AM |
| leaky rear oil seal | CHUCK | Newbies | 1 | 08-01-05 10:24 PM |
| Jag Diff Pinion Oil Seal Renewal | bitterandy | General Tech Tips & Questions | 0 | 08-09-03 11:20 AM |
| Diff Oil Seal Replacement | Warren | General Tech Tips & Questions | 3 | 02-01-03 08:28 PM |
