Old 19-06-06, 10:39 AM
chedz's Avatar
SVA and side pipe brackets.
Hello,
I fitted the side pipes at the weekend. Not quite finished but looking very good.
I was wondering how the brackets will get on at the SVA, are they somehow exempt? They will certainly be a bit sharp and hard, so I assume the SVA man won't be bending down that far to check them? There are also some clamps around them to hold the final bend on which are also pretty nasty looking. The sharp bits will be on the underside, tucked out the way but still...
Also, whats the minimum gap betwix bodywork and sidepipe to avoid burn marks. I can just about get my finger in at the moment, it could be adjusted out a bit but would be some effort so if its ok I'll leave it.
Thanks!
Graham
Old 19-06-06, 01:19 PM
dave's Avatar
Tuuurn up da bass.
Re: SVA and side pipe brackets.
All depends on how much the brackets protrude.
Make a 30/60/90 triangls from some cardboard and then place it on the floor with the pointy end sticking up. Slide it up to the side of your car. Where the triangle touches your car this is called the sill line. Anything below this is exempt and anything it touches or is above must comply with the min. rad. rules.
The gap you have sounds fine for the distance from the bodywork.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 19-06-06, 01:57 PM
chedz's Avatar
Thanks, I think I understand, is this diag right? anything in the triangle must comply, anything outside is not tested. I assumed the triangle goes against the pipe and not the bodywork? So if it's as per this diag the bracket isn't tested?
Graham
Old 19-06-06, 01:59 PM
Couldn't resist......
If only life was as kind to me as my wife is....
Old 19-06-06, 02:01 PM
chedz's Avatar
Now we know who it was that sprayed "Call BC_SUV for a good time" in the toilets at Eastbourne train station.
Old 19-06-06, 02:07 PM
dave's Avatar
Tuuurn up da bass.
Hi Graham.
Bob on!. As your diagram is your pipe bracket is fine.
Pro Dax Builder
Current builds:-
DB REPLICAS
side pipe fitting fcukruss AK Technical Questions 16 09-04-08 10:40 PM
ref Best Side pipe supplier fab168 General Cobra Discussion 19 25-05-06 10:10 AM
Side pipe dimensions kevchard General Tech Tips & Questions 6 30-11-04 03:22 PM
Front brake pipe brackets. & rear lower arm mods. Andy302 General Tech Tips & Questions 4 26-10-04 08:30 PM
side pipe repacking clive a brown General Cobra Discussion 9 10-03-03 08:04 AM
