Old 09-09-06, 11:45 AM
Wiring problem....
Now then, Im majorly bad at wiring and as such Ive got a small problem.
Ive done the front lights, front indicators and rear brake and indicator lights (havent done the side indicators.
What I get when I try my lights is left hand side works perfectly, lhs brake, full beam dipped ect.
what I dont get is any indicators, and the rhs no lights or brakes or anything... so any ideas where I start on this one and what sort of procdure i need to follow to sort this one out?
cheers
Ben:thumb:
kreativejuice...
www.kreativejuice.co.uk
Old 09-09-06, 12:28 PM
dave's Avatar
Tuuurn up da bass.
Re: Wiring problem....
Hi Ben.
You might have a couple of problems. The brake lights are linked, so if one side works then so should the other.
For the rest, start with the fuses and then go through the loom to make sure all your connections are plugged in correctly.
It'll be something silly, it always is.
Good luck.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 09-09-06, 01:55 PM
check then check agaian and then check again that all the earths are really well made
Tin top problem oglyoodoo The Cockpit 11 05-09-07 09:29 PM
SVA problem: really need some HELP ! Cobra power General Tech Tips & Questions 26 04-09-06 10:13 PM
Wiring loom: fan wiring TheUnixKid Pilgrim Sumo Technical Questions 1 11-08-05 11:27 AM
4.6 Problem VinceGledhill Engine Tech Tips & Questions 5 06-08-03 04:44 PM
DAX WIRING PROBLEM macca DAX Technical Questions 2 08-01-03 09:31 PM
