| Holley Carb Questions This question might be quite hard to follow as I do not know about carbs at all. I have a Holley carb as shown and intend to fit to my build this weekend. I have fitted part 111 and want to know if there should be something in the holes marked 1 and 11. 1 and 11 look blind, but I am not sure. I fitted part 111 as I bought a fuel pipe (solid) and the gap between the two inlet ports was incorrect without it. There is a screw in the part marked 1111. When i do start it up one day I will have two fire extinguishers !
__________________ David Clifford AK427, Tremec and Stroker. |
| Re: Holley Carb Questions You are missing quite a few things. The two brass screws hide the adjusting screw for the floats and are nothing to do with the fuel feed. The fuel line fits in the two large downward pointinh orrifices that have threads around the inner circumference, You will need fittings. The hole highest up in the body accomodates a brass blanking screw and washer and is solely for the purpose of shutting off the hole to the float bowl which is opened when setting the float height. The lower small hole accomodates the needle that resticts the idle circuit and is used for setting the idle mixture. It fits in with a small cork or fibre surround collar and is a screw fit. Judging by your post you desperately need to get hold of a manual as god knows what else is missing. Where did you get it from. Mike |
| Re: Holley Carb Questions Quote:
| Holley Carb | bazbo | Parts for sale | 5 | 07-09-07 09:22 PM |
| holley carb | Clarkson | General Tech Tips & Questions | 10 | 29-04-03 11:18 PM |
| Holley 390 CFM Carb | sumov8 | General Tech Tips & Questions | 8 | 09-01-03 07:45 PM |
| Holley carb choice on 350 sbc | ian | General Tech Tips & Questions | 16 | 10-05-02 10:31 PM |
| Holley Carb Attachments . | Dan | General Tech Tips & Questions | 5 | 08-01-02 08:13 PM |
