| Brake fluid I did a search and there are many views on the subject so I phrase my question carefully. This is not a debate on mineral verses silicon, I hope. Is Comma Dot 4 synthetic brake fluid ok for my jag brakes and rover master. reepower slave and girling master ? as ever thanks in advance.
__________________ David Clifford AK427, Tremec and Stroker. |
| Re: Brake fluid Thanks for the reply. is Is Comma Dot 4 synthetic brake fluid , mineral ?
| Re: Brake fluid Quote:
They do a Mineral based version which is called LHM, no good for your application.
__________________ AK 427 FOR SALE AK427 FOR SALE PistonHeads AK for sale Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
| Re: Brake fluid As I understood, it is not wise to use silicone brake fluid with the older applications, ie XJ Jag, because there is a problem with the way this fluid reacts with the rubber seals. You do not get the required swell from the rubber and therefore can get seal problems and early failure. Not sure what happens if using the newer XJ40 setup. I could be totally wrong! So all I will say is that my local brake specialist who is well up on older cars and bikes said don't bother. Dot4 mineral is fine!
__________________ Ian DAX 454 Chevy The closer I get to getting it running, the further away I actually am!! |
Standard requirement of vehicles until the early 1980's. Suitable for use in Drum, disc, tandem brake and hydraulic clutch systems. Can be mixed safely with DOT 4 Fluid. LHM Plus Mineral based fluid for hydraulic systems.Suitable for certain Citröen, Peugeot and Rolls Royce & Bentley models (where components are coloured green). CAUTION: Check owners manual for application.
| Brake fluid | Dek | General Tech Tips & Questions | 12 | 10-08-07 11:57 AM |
| Brake fluid vaporisation | nbracken | General Tech Tips & Questions | 8 | 10-04-05 08:28 PM |
| GDJAG Brake Fluid | Trigger | General Tech Tips & Questions | 10 | 09-02-05 06:47 AM |
| Brake fluid | Pat | General Tech Tips & Questions | 1 | 15-07-04 09:06 AM |
| Brake fluid | chesterak | General Tech Tips & Questions | 5 | 09-11-02 06:52 PM |
