| max rev setting chevy350 not sure if this question can be answered without supplying losts of details on my engine, but for now a ballpark figure would help. About to install an ignition control unit, with a rev. limiter function. What is a sensible setting for a chevy350? Thanks Patrick |
| Re: max rev setting chevy350 Not what you wanted to hear, but is it bog srandard or beefed up. If its bog standard you should be limiting it to around 5500 RPM occasional. If it is balanced and had decent fixings then 5750 should be your limit. If you are using aftermarket uprated rods etc then depending on the product, safe rev limits vary, but most decent aftermarket (NOT BRAND REPLACEMENT AS STANDARD) will see 6000 RPM again as long as you have decent fixings, cxarried out stress relief and had the rotating assembly professionaly balanced. Even if you have an engine thats components can take high RPM remember your Flywheel quality comes into play at anything above 6000 RPM (if you want to keep your legs). All the best Mike |
| Re: max rev setting chevy350 Quote:
yourname@hotmail.com SMTP error from remote mail server after RCPT TO:<yourname@hotmail.com>: host mx4.hotmail.com [65.54.244.104]: 550 Requested action not taken: mailbox unavailable
| Re: max rev setting chevy350 done, thanks. |
| Re: max rev setting chevy350 Well, to be honest when I ordered my engine in the US, I trusted that the price/quality was ok and decided on a standard package: (http://www.pro-formanceunlimited.com/). I'm not able to fully judge the specs of the engine, but are of course very interested in your comments. Hereby the details I received when I ordered the engine, sorry if I wrote down less important/irrelevant details - Chevy 350, 1979 block, bored and honed - Cast iron precision ground crank assembled W/Tri Metal Clevite 77 Rod and main bearings -Set of I-beam connecting rods W/ARP Rod Bolts - Assembled with a set of hand filled perfomance rings -A three piece true double roller timing set - A crane performance camshart (hyrdaulic lifte) - A set of high rev lifterss - Set of Edelbrock Alu Performance Cylinder Heads With 2.02 Int And 1.60 Exh valves, Scew in studs and Guide planes - A set of chrome Moly Push Rods - Set of new performance long slot ocket Arm W/1.5 ratio - Edelbrock Torker II 5001 Series intake manifold - Edelbrock 600cfm Carburetor - high performance HEI distributor - HIgh Volume Oil pump - Performance balancer |
I think you've put an extra 0 on the end mate :rotfl: :rotfl:
__________________ Gareth Lovell 427 |
| Re: max rev setting chevy350 Your in the wrong place mate,please stay in the Ford section!:rotfl: :rotfl:
If they have done a good job with balancing etc, I still believe you should be limiting yourself to 5750. Depending on your cam with the inlet etc you would not be benefiting much by extending this anyway. High performance HEI ? I only know the standard HEI distributor which has its own issues above around 5800 RPM anyway - dont know whether it was down to Spark scatter or not, although I believe that there is a kit which can solve this All the best. Mike |
| Setting up a Webber 500 | Sidecarbod | General Tech Tips & Questions | 19 | 05-04-06 12:26 AM |
| torque setting | Clarkson | General Tech Tips & Questions | 7 | 06-11-05 09:09 PM |
| Setting the Mixture | mr bidd | Engine Tech Tips & Questions | 2 | 09-07-05 07:15 AM |
| setting the speedo | greenster | Pilgrim Sumo Technical Questions | 2 | 05-06-05 07:39 PM |
| ETB speedo setting | simon | General Cobra Discussion | 7 | 28-02-04 03:25 PM |
