| ETB Speedo Sensor Hello Can someone tell me how to test the magnetic induction sensor from ETB. I can't get any signal. I have tried to change the gap between the sensor and the magnet but the gauge still says no pulses. How do you test the sensor? There are two wires, one red and one black. Can I some how use a 12 Volt light bulb and turn the wheel by hand to see if the sensor gives a signal?????????????? ![]()
__________________ Dax Tojeiro fully galvanised chassis! Painted in Ferrari Tour de France blue 1975 SBC 350 / Tremec T5 On The Road. Yupee! http://www.cobraclub.com/gallery/sho...00&ppuser=1245 |
| Re: ETB Speedo Sensor Hello Pete, Thanks for your reply. I will try to get some information from the ETB website. Otherwise I will give them a ring. :thumb:
| Re: ETB Speedo Sensor Might be an obvious thing to ask but you have changed the settings in the speedo itself haven't you as they normally come set to the maximum pulse count ![]()
| Re: ETB Speedo Sensor Hello Martin I spoke to John at ETB and he told me the resistance over the sensor should be 130 ohm. My one has 0.2 ohm. According to John it is dangerous to solder the wires as they are likely to overheat and damage the sensor. :thumb: :thumb:
| GD Speedo sensor | Glyn_Turner | General Tech Tips & Questions | 2 | 26-08-05 01:12 PM |
| ETB Speedo and SD1 sensor | chesterak | General Tech Tips & Questions | 15 | 06-05-05 03:55 PM |
| Jag Speedo Sensor | Grease Monkey | General Cobra Discussion | 8 | 14-10-04 12:04 PM |
| Speedo Sensor | greenster | Pilgrim Sumo Technical Questions | 7 | 06-07-04 12:10 AM |
| Speedo Sensor location. | Dan | General Tech Tips & Questions | 16 | 05-08-02 08:45 PM |
