| Jag Suspension + stainless steel nuts & Bolts Hi I am in the middle of renovatingreconditioning a set of Jag axles (front and Back) and brakeshubs for my GD Cobra build. Can anyone advise me on using stainless steel nuts and bolts for the axlesuspension rebuild? Has anyone done this and if so where did they get them from. If I replace all the nuts and bolts from "Ward engineering" will they be SS or normal nutsbolts? Thanks for any advice Regards Martin
__________________ GD427 Mk4 - Chassis rolling. 3.5 RV8 - Engine in and running. MK4 Body ordered (in black)!! GD Chassis J0258. People who never make mistakes, never make anything!!! www.martins-cobra.co.uk |
| Re: Jag Suspension + stainless steel nuts & Bolts Quote:
__________________ www.betterbiker.com |
| Re: Jag Suspension + stainless steel nuts & Bolts I echo tarmacscratcher's comments. Most stainless "dress up" fasteners you can buy are of very poor tensile strength compared to normal hiigh tensile bolts. In addition, stainless fasteners are prone to "galling" (seizing up to you and me!) Whilst there are grades available that would be suitable, to understand them, identify them, and track them down is a task for an expert. Try a search here on "stainless" or similar, there has been good info posted in the past. Of course, you might decide to become such an expert, but personally, wherever a fastener is safety critical, like suspension mountings, propshaft couplings, engine mounts, safety belt mounts, etc., I would just use an 8.8 or better high tensile normal steel nut & bolt. Edit - Oh, and what Purple said too.
| Re: Jag Suspension + stainless steel nuts & Bolts Please don't use S/S bolts/nuts on any critical components, as said before the tensile strength is very poor, use good quality high tensile 8.8 grade fasteners. why not carry out a little experiment, 2 M10 bolts one S/S and the other 8.8, slowly torque them up and see which one shears first! Russ
| Re: Jag Suspension + stainless steel nuts & Bolts If you would like to learn more, go here: http://home.jtan.com/~joe/KIAT/kiat_2.htm
| Re: Jag Suspension + stainless steel nuts & Bolts The only benefit I can see from using stainless apart from looks is one of corrosion. If you use Bright Zinc Plate high tensile bolts and coppaslip grease then you shouldn't have any bother disassembling at a later date.
I get the message and will not bother with the stainless. Regards Martin
| Stainless steel tubing ???? | darren | Pilgrim Sumo Technical Questions | 9 | 18-08-07 04:00 PM |
| Stainless steel bolts | martin_t | Engine Tech Tips & Questions | 5 | 11-05-06 11:14 AM |
| Stainless Steel Bottles etc. | BIGUNDIES | General Cobra Discussion | 8 | 23-01-06 05:23 PM |
| Drilling stainless steel | Robin427 | General Tech Tips & Questions | 16 | 22-06-05 09:59 PM |
| stainless suspension bolts | simon | General Cobra Discussion | 30 | 27-03-05 11:37 AM |
