| Re: dodgy starter motor When the starter motor doesn't engage can you hear it spinning freely or does it just click? If you just get the click it could be a weak solenoid not pulling the gear into the flywheel. The switch that operates the starter is also on the end of the solenoid plunger so if it is weak it will not operate the starter.Also check the gear on the end of the motor is free to slide in and out. Rimmers sell just a solenoid kit that could be a cheaper option. http://www.rimmerbros.co.uk/rimmer/rover/sd1/electrical Craig.
| Re: dodgy starter motor Jeff, If you are SURE that the set-up works on the bench, and I am assuming that you mean installed on the engine on the bench, then I feel it must be high resistance in the wiring, check the positive and negative connections on the battery, and the connections on the starter motor, and the ones lots of people forget, the negative to earth, and the most common fault, the earth strap from the chassis to the engine. regards bloke. |
| Re: dodgy starter motor Bit the bullit, new starter £55 off evilbay plus a tenner delivery jeff
__________________ Jeff My next one WAS going to be AK but beginning to think I am to old to build anymore cars |
| Old Starter Motor | martin_t | Engine Tech Tips & Questions | 1 | 20-08-07 10:51 PM |
| Starter Motor | martin_t | Gardner Douglas Technical Questions | 1 | 14-08-07 08:20 AM |
| Dodgy Ebay Motor | jonbillings | General Cobra Discussion | 73 | 01-02-06 03:26 PM |
| starter motor | kev | Engine Tech Tips & Questions | 2 | 09-04-03 01:40 PM |
| starter motor | Bernie | General Tech Tips & Questions | 9 | 07-11-02 09:28 PM |
